[mapserver-users] Runtime Substitution Not Working
Helen San Segundo Navazo
hsansegundo at meteo.cat
Mon May 21 12:23:20 EDT 2012
hi Ryan,
try to add the validation pattern inside the layer tag
METADATA
'file_validation_pattern' "[A-Z0-9._%+-|'\(\)]"
'default_file' "ultima_imatge" #-------> this is to give a
value when you don't put the &file=value in the url call
END
VALIDATION
'file' "[A-Z0-9._%+-|'\(\)]"
END
DATA '%file%'
Helen
El 21/05/12 17:55, Ryan Dussiaume escribió:
> Hi,
> I'm trying to use runtime substitution to replace the DATA setting of
> the Mapfile at runtime. I'm running in tile mode and using GRD raster
> format.
> Here's the mapfile:
> MAP
> NAME Blah2
> STATUS ON
> SHAPEPATH "C:/Contours/FSGrids"
> PROJECTION "init=epsg:26918" END
> LAYER
> NAME Contour
> TYPE RASTER
> STATUS ON
> DATA '%file%'
> CLASS
> NAME "Contour"
> END
> END # Layer
> END
> And here is a sample request for one of the tiles that I've copied
> from Fiddler ...
> http://<my
> server>/cgi-bin/mapserv.exe?map=C:/ms4w/Maps/mapfile2.map&file=Site_1_1_1_Total.grd&mode=tile&layers=Contour&tilemode=ve&tile=03023032203031
> <http://%3cmy%20server%3e/cgi-bin/mapserv.exe?map=C:/ms4w/Maps/mapfile2.map&file=Site_1_1_1_Total.grd&mode=tile&layers=Contour&tilemode=ve&tile=03023032203031>
> If I put the filename directly in the DATA setting of the mapfile it
> works fine and I see the grid in Virtual Earth. If I try to use
> runtime substitution to put the file name it just produces blank tiles.
> Any help is very much appreciated, thanks!
> Ryan
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120521/b78d1a72/attachment.html
