[mapserver-users] Runtime Substitution Not Working
Ryan Dussiaume
ryan.dussiaume at mentum.com
Mon May 21 13:00:50 EDT 2012
Worked like a charm, thanks!
Ryan
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Helen San Segundo Navazo
Sent: May 21, 2012 12:23
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Runtime Substitution Not Working
hi Ryan,
try to add the validation pattern inside the layer tag
METADATA
'file_validation_pattern' "[A-Z0-9._%+-|'\(\)]"
'default_file' "ultima_imatge" #-------> this is to give a value when you don't put the &file=value in the url call
END
VALIDATION
'file' "[A-Z0-9._%+-|'\(\)]"
END
DATA '%file%'
Helen
El 21/05/12 17:55, Ryan Dussiaume escribió:
I'm trying to use runtime substitution to replace the DATA setting of the Mapfile at runtime. I'm running in tile mode and using GRD raster format.
Here's the mapfile:
MAP
NAME Blah2
STATUS ON
SHAPEPATH "C:/Contours/FSGrids"
PROJECTION "init=epsg:26918" END
LAYER
NAME Contour
TYPE RASTER
STATUS ON
DATA '%file%'
CLASS
NAME "Contour"
END
END # Layer
END
And here is a sample request for one of the tiles that I've copied from Fiddler ...
http://<my server>/cgi-bin/mapserv.exe?map=C:/ms4w/Maps/mapfile2.map&file=Site_1_1_1_Total.grd&mode=tile&layers=Contour&tilemode=ve&tile=03023032203031<http://%3cmy%20server%3e/cgi-bin/mapserv.exe?map=C:/ms4w/Maps/mapfile2.map&file=Site_1_1_1_Total.grd&mode=tile&layers=Contour&tilemode=ve&tile=03023032203031>
If I put the filename directly in the DATA setting of the mapfile it works fine and I see the grid in Virtual Earth. If I try to use runtime substitution to put the file name it just produces blank tiles.
Any help is very much appreciated, thanks!
Ryan
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120521/982270f2/attachment.html
