[mapserver-users] mapcache_seed and DIM variables - order of
folders created
Helen San Segundo Navazo
hsansegundo at meteo.cat
Wed May 23 07:58:05 EDT 2012
hi ,
after some problems installing mapcache now I can use it perfectly.
I'm testing the mapcache_seed using dim variables and it works but when
the folders are created I don't know if it's possible to create it in a
determinate order.
I have a mapfile that accepts runtime substitution variables (date,
hour, minute)
My mapcache.xml has defined the dimensions tag inside the tileset tag
with the 3 variables
if I execute mapcache as:
sudo ./mapcache_seed -c /var/www/mapcache/mapcache.xml -t
Meteosat_params -g WGS84 -z 0,3 -M 2,2 -D "minute=00" -D "hour=14" -D
"date=20120314"
I obtain:
--Meteosat_params
|-------WGS84
|-------00 (minute)
|-------14 (hour)
|-------20120314 (date)
It would be better for what I need if the folder order could be
date-hour-minute instead of minute-hour-date
I've tried to change the order in the mapcache_seed request but the
result is always the same, anybody knows if it's possible to define the
folder's order.
Thanks in advance,
Helen
