[mapserver-users] Create new shapefile using C# MapScript ShapFileObj
sharad
fine_sharad at hotmail.com
Fri Nov 2 05:13:09 PDT 2012
ShapeFileObj class in C# mapscript
I'm trying to export spatial data in esri shape file format. I am using to
export a layer data of map object into separate shapefile. I'm not having
any run-time failures but my result has only .SHP, .SHX files.
layerObj lyrObj12 = baseMap.getLayerByName("District"); // baseMap
is mapObj and District is the layerObject name of baseMap
shapeObj shapeObj = new OSGeo.MapServer.shapeObj(-1);
resultObj robje = new resultObj(0);
lyrObj12.open();
shapeObj = lyrObj12.getShape(robje);
// lineObj lobj= baseMap.g
shapefileObj shapeFIle = new shapefileObj(csvFilePath +
"\\testShapeFile.shp", (int)MS_SHAPE_TYPE.MS_SHAPE_LINE); //csvFilePath is
the location of the local drive
shapeFIle.add(shapeObj);
shapeObj.Dispose();
shapeFIle.Dispose();
Any suggestions would be appreciated.
Regards
Sharad Subedi
View this message in context: http://osgeo-org.1560.n6.nabble.com/Create-new-shapefile-using-C-MapScript-ShapFileObj-tp5013528.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
