[mapserver-users] fast cgi MapServer (version 6.0.3) vs cgi with awms getmap request
karsten
karsten at terragis.net
Thu Nov 8 10:15:13 PST 2012
Hi Andreas,
>> I just tested fast cgi MapServer (version 6.0.3) vs cgi with a wms
>> getmap request againtst a map file with 73 postgis layers (and
>> PROCESSING "CLOSE_CONNECTION=DEFER" setting for each layer.)
> IMHO that processing option avoids reopening a connection to the same
database for a single request. Once the request is done the the connection
will be closed.
I thought that setting allows to open the db connection only once , keep it
open until all layers data are read and will prevent closing and opening
connections in between layers ?
> FastCGI only reduces the startup time (as the processes are already
running) and therefore improves mostly simple requests where startup time is
significant compared to content generation - like GetCapabilities and
GetLegendGraphic. In your case parsing the map file with 73 layers already
introduces a significant workload for every request, independent of the
request type.
> That gap should be closed by mod_mapserver which associates a map file
with an URI and keeps a copy of the parsed object in memory wich usually
keeps database connections open.
I searched the list and the MapServer doc about the Apache ? Module
mod_mapserver, however I could not find almost any reference to it other
than it is on the wish list for v 6.2 ? Does it already exist in MapServer
6.0.3 And if so - is there any info how to configure that feature ?
Cheers
Karsten
Email scanned by PC Tools - No viruses or spyware found.
(Email Guard: 9.0.0.2308, Virus/Spyware Database: 6.20820)
http://www.pctools.com/
