[mapserver-users] tinyows
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Nov 9 02:04:11 PST 2012
Forum is right but obviously there are not many people doing WFS-T with OpenLayers against TinyOWS installed on Windows. If you are totally jammed I would recommend you to leave TinyOWS aside for a while and try to make your OpenLayers application to work with Geoserver WFS-T. I believe you will have success with it.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: aho [mailto:forum.email.a at googlemail.com]
> Lähetetty: 9. marraskuuta 2012 11:27
> Vastaanottaja: sdikiy at volz.ua
> Kopio: Rahkonen Jukka; mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] tinyows
> Hi again,
> I am still searching and not finding something. I setup everything again with
> the WFS-T tutorial. Now I am getting the following error message:
> [Thu Nov 08 16:32:21 2012] [ERROR] local list type: A type, derived by list or
> union, must have the simple ur-type definition as base type, not
> '{http://www.opengis.net/gml}doubleOrNullList'.
> Am I right with this forum? Because actually nobody replies.
> Am 11/6/2012 1:30 PM, schrieb aho:
> > Hey,
> > I still havn´t found the problem with the tinyows - but at the moment
> > there is no error message when i am loading the wfs. Also fiddler
> > doesn´t list the tinyows.exe anymore. But my proxy is correct - I can
> > load it via uDig and ArcMap. QGIS has a problem, but there is not a
> > single error in the tinyows log file - just events and sqls are
> > listed, that looks quite good. With Open layers there is nothing
> > logged - it seems like the request is not send.
> > Is there any limitation for the version? I downloaded the latest
> > (2.12) one, but on the tinyows page is version 2.09 listed?!
> > Kind regards
> > Am 11/2/2012 3:29 PM, schrieb Serge Dikiy:
> >> Hi,
> http://translate.google.com/translate?sl=ru&tl=en&js=n&prev=_t&hl=en&
> >> ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fgis-
> lab.info%2Fforum%2Fviewto
> >> pic.php%3Ff%3D41%26t%3D10329
> >> BR
> >> On Fri, Nov 2, 2012 at 4:15 PM, aho <forum.email.a at googlemail.com>
> >> wrote:
> >>> Hi Jukka,
> >>> ok, I solved the problem with the requests. The following returns
> >>> from
> >>> tinyOWS:
> >>> <?xml version='1.0' encoding='UTF-8'?> <ows:ExceptionReport
> >>> xmlns='http://www.opengis.net/ows'
> >>> xmlns:ows='http://www.opengis.net/ows'
> >>> xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
> >>> xsi:schemaLocation='http://www.opengis.net/ows
> >>> http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd'
> >>> version='1.1.0' language='en'>
> >>> <ows:Exception exceptionCode='InvalidParameterValue'
> >>> locator='request'>
> >>> <ows:ExceptionText>XML request isn't valid</ows:ExceptionText>
> >>> </ows:Exception>
> >>> </ows:ExceptionReport>
> >>> Here is the errorlog:
> >>> Fri Nov 02 15:11:46 2012] [EVENT] == FCGI START == [Fri Nov 02
> >>> 15:11:46 2012] [QUERY] <wfs:GetFeature
> >>> xmlns:wfs="http://www.opengis.net/wfs" service="WFS"
> version="1.0.0"
> >>> xsi:schemaLocation="http://www.opengis.net/wfs
> >>> http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd water
> >>> http://127.0.0.1:8000/redir/cgi-
> bin/tinyows.exe?service=wfs&request=GetFeature&version=1.0.
> 0&typename=water:armature"
> >>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-
> instance"><wfs:Query
> >>> typeName="feature:armature" xmlns:feature="water"><ogc:Filter
> xmlns:ogc="http://www.opengis.net/ogc"><ogc:BBOX><ogc:PropertyName
> >g
> >>> eometry</ogc:PropertyName><gml:Box
> >>> xmlns:gml="http://www.opengis.net/gml"
> >>> srsName="EPSG:32740"><gml:coordinates
> >>> decimal="." cs="," ts=" ">-2866.3885602952,-1910.9257068634
> 2866.3885602952,1910.9257068634</gml:coordinates></gml:Box></ogc:BBO
> >>> X></ogc:Filter></wfs:Query></wfs:GetFeature>
> >>> [Fri Nov 02 15:11:46 2012] [ERROR] Element
> >>> '{http://www.w3.org/2001/XMLSchema}import': Failed to locate a
> >>> schema at location
> >>> 'localhost/cgi-
> bin/tinyows.exe?service=WFS&request=DescribeFeatureType&version=1.0.
> 0'.
> >>> Skipping the import.
> >>> '{http://www.opengis.net/wfs}GetFeature': No matching global
> >>> declaration available for the validation root.
> >>> [Fri Nov 02 15:11:46 2012] [ERROR] XML request isn't valid [Fri Nov
> >>> 02 15:11:46 2012] [EVENT] == FCGI SHUTDOWN == [Fri Nov 02 15:11:46
> >>> 2012] [EVENT] == TINYOWS SHUTDOWN ==
> >>> Has it something to do with the schema? I found a post with
> >>> something similar
> >>> (http://osgeo-org.1560.n6.nabble.com/TinyOWS-wrong-call-in-
> OpenLayer
> >>> s-InvalidParameterValue-XML-request-isn-t-valid-td5009059.html)
> >>> and replaced all my old tinyows files and copied the ones from the
> >>> ms4w homepage.
> >>> Do you have some more ideas?
> >>> Am 11/2/2012 10:56 AM, schrieb Rahkonen Jukka:
> >>> Hi,
> >>> Yes, it seems to be OpenLayers question then. However, do still
> >>> capture the requests because without them you cannot understand
> what
> >>> happens really. My guess is that something in wrong in how
> >>> EPSG:31467 and EPSG:32740 are used and OpenLayers is requesting data
> >>> from a place where there are no data.
> >>> -Jukka-
> >>> aho wrote:
> >>> Hi Jukka,
> >>> thanks a lot for your answer and the good tips! I tried all of the
> >>> links
> >>> and they are working. Also I checked it in QGIS and there I can load
> >>> it too.
> >>> So I guess it will be better to write again to the openlayers
> >>> mailinglist?!
> >>> Am 11/2/2012 10:21 AM, schrieb Rahkonen Jukka:
> >>> Hi,
> >>> You must capture the traffic between OpenLayers and TinyOWS. I am
> >>> using myself Fiddler2 proxy but I suppose that Firebug can show you
> >>> what OpenLayers is sending and high enough TinyOWS logging level
> >>> will also gather requests into tinyows log. The software is not
> >>> important but you just have to get the requests so you can resend
> >>> them with a browser or some other tool that yuo can control and see
> >>> what happens. You can also include the requests in your further
> >>> mails. Then the question will be "OpenLayers is sending this and
> >>> TinyOWS is sending back that, what's wrong?" and it will be much
> >>> easier to answer.
> >>> As always with WFS, start with these requests with a browser before
> >>> doing anything with OpenLayers:
> >>> http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe?service=wfs&request=
> >>> GetCapabilities&version=1.1.0
> DescribeFeatureType&version=1.1.0&typename=water:pipeline_segment
> GetFeature&version=1.1.0&typename=water:pipeline_segment&maxFeatu
> res
> >>> =10
> >>> If all those requests work you know that TinyOWS works with those
> >>> basic requests and if OpenLayers application does not get data the
> >>> reason in probably in the application code.
> >>> -Jukka Rahkonen-
> >>> aho wrote:
> >>> hello!
> >>> I have a problem with the configuration of tinyows. I have the
> >>> following
> >>> settings in my xml file:
> >>> <tinyows online_resource="localhost/cgi-bin/tinyows.exe"
> >>> schema_dir="C:\ms4w\apps\tinyows\schema\">
> >>> <pg host="localhost" user="postgres" password="postgres"
> >>> dbname="watergis" port="5432"/>
> >>> <metadata name="TinyOWS Server"
> >>> title="TinyOWS Server - WFS-T Frida Service" />
> >>> <contact name="TinyOWS Server"
> >>> site="http://www.tinyows.org/"
> >>> email="tinyows-users at lists.maptools.org" /> <layer
> >>> retrievable="1"
> >>> writable="1"
> >>> ns_prefix="water"
> >>> ns_uri="http://localhost/"
> >>> name="pipeline_segment"
> >>> title="pipeline_segment"
> >>> table= "pipeline_segment"
> >>> srid="32740"
> >>> schema="water"/>
> >>> </tinyows>
> >>> >if I enter tinyows --check I get the following back:
> >>> C:\ms4w\Apache\cgi-bin>tinyows --check
> >>> TinyOWS version: 1.0.0rc3
> >>> FCGI support: Yes
> >>> Config File Path: C:\ms4w\apps\tinyows\tinyows.xml (TinyOWS XML)
> >>> PostGIS Version: 2.0.0
> >>> PostGIS dsn: host=localhost user=postgres password=postgres
> >>> dbname=watergi
> >>> s port=5432
> >>> Output Encoding: UTF-8
> >>> Database Encoding: UTF8
> >>> Schema dir: C:\ms4w\apps\tinyows\schema\
> >>> Display bbox: Yes
> >>> Estimated extent: No
> >>> Check schema: Yes
> >>> Check valid geoms: Yes
> >>> Available layers:
> >>> - water.pipeline_segment (32740) -> water.pipeline_segment [RW]
> >>> which looks acutally quite good. But when i am trying to include
> >>> that
> >>> into my openlayer map - I always get 0 features back! Here the code
> >>> for
> >>> openlayers:
> >>> wfs = new OpenLayers.Layer.Vector("Editable Features", {
> >>> strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
> >>> projection: new OpenLayers.Projection("EPSG:31467"),
> >>> protocol: new OpenLayers.Protocol.WFS({
> >>> version: "1.1.0",
> >>> srsName: "EPSG:32740",
> >>> url:
> >>> "http://127.0.0.1:8000/redir/cgi-bin/tinyows.exe",
> >>> featureNS : "tows",
> >>> featureType: "pipeline_segment",
> >>> geometryName: "geometry",
> >>> schema:
> bin/tinyows.exe?service=wfs&request=DescribeFeatureType&version=1.1.0
> &typename=water:pipeline_segment"
> >>> Someone an idea?
> >>> _______________________________________________
> >>> mapserver-users mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
