[mapserver-users] fast cgi MapServer (version 6.0.3) vs cgi with awms getmap request
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Fri Nov 9 02:16:02 PST 2012
Hello Thomas,
> In FastCGI mode, a connection will be kept open during the
> lifecycle of the fastcgi process, i.e. the connection will
> not be closed at the end of a request.
Damn, you're right. Had a look at the code and tracking down the
chain I saw:
mapserv.c: msFreeMapServObj()
maptemplate.c: msFreeMap()
mapobject.c: msCloseConnections()
mapfile.c: vtable->LayerCloseConnection() [for each layer]
But PostGIS layers don't provide a LayerCloseConnection() and use the
pooling API instead - and that is the magic that keeps the connection.
Sorry for the confusion.
> It should be noted that these limitations would also apply to a
> homemade mapscript script that reuses a mapObj for multiple requests.
I overcame that problem by using msCopyMap(). It's not that elegant than
using separate datastructure for service config and work data but still
avoids the costly invocation of the parser.
Regards
