[mapserver-users] SDE 10.x support...
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Nov 14 12:43:58 PST 2012
Yes. I'm on a 64-bit Linux box and mapsde.c compiled fine against the 10.0 client libs. Problem was it didn't work until I did two things:
- Add "CFLAGS=-DSDE64" to configure call.
- Fix most of warnings (all but one) that result in the above change (change long's to ms_int32), see https://github.com/mapserver/mapserver/issues/4521.
I was working against 6.0 and it looks like 6.2 will require the same changes. If you're on a 32-bit OS you probably don't need to change anything.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Alan Boudreault
Sent: Wednesday, November 14, 2012 2:31 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] SDE 10.x support...
Steve, I was looking to use SDE 10 too, have you been able to get it to work?
Alan
On 12-11-01 03:57 PM, Lime, Steve D (DNR) wrote:
> Hi all: Has anyone successfully used the SDE 10.x client libs with
> MapServer 6.0+? Compiles ok but I've had no luck actually using SDE layers.
> Steve
> *StEVE LIME | *DATA & Applications MANAGER
> MN.IT Services @ MnDNR
> 651-259-5473 (w) *|* 651-297-4946 (f) *|* steve.lime at state.mn.us
> <mailto:Your.name at state.mn.us>
> // <http://www.mn.gov/oet>//
> Information Technology for Minnesota Government *|* mn.gov/oet
Alan Boudreault
http://www.mapgears.com/
