[mapserver-users] PerlMapscript on Windows (Helmut Seidel M.A.)
Puneet Kishor punk.kish at gmail.com
Wed Nov 14 14:01:19 PST 2012
On Nov 14, 2012, at 12:34 PM, lfilak at medinaco.org wrote:
>> Date: Wed, 14 Nov 2012 19:20:48 +0100
>> From: "Helmut Seidel M.A." <info at knowhow-la.de>
>> To: mapserver-users at lists.osgeo.org
>> Subject: [mapserver-users] PerlMapscript on Windows
>> Message-ID: <50A3E100.5020400 at knowhow-la.de>
>> Content-Type: text/plain; charset=ISO-8859-15; format=flowed Hello everybody, I've just started on Mapserver  again - I normaly use (opensuse 12.2-/ ubuntu 12.04-) Linux and and would like to use perl scripting. On both Linuxes it is no problem to install Perl Mapscript but as far as I've seen MS4W and OSGEO don't come with Perl Mapscript. As my Scripts have to run on Windows I wonder whether there is an easy way to install it or does it mean compiling for Windows? Is there some kind of howto for installing PerlMapscript? Thanks very much
> In the source directory mapscript/perl the README file explains the compilation process. I've never tried on Windows however and don't know if it will work.
(Hi Lowell). I am pretty sure it won't work as compiling it requires SWIG, and, of course, a compiler. So, someone has to make the module (or dll or whatever it is called on Windows) and provide it.
Puneet Kishor
