[mapserver-users] [TinyOWS] Inserting feature and XML schema validation
Тимур Галиаскарович Суфиев t.sufiev at acti.ru
Fri Nov 16 03:32:13 PST 2012
I found the problem (just in case it may be useful for someone): wfs layers in Javascript were using
featureNS: "http://www.tinyows.org"
while all layers in tinyows.xml used
ns_uri="http://www.tinyows.org/"
Every symbol matters in deciding whether xml namespaces are the same, so adding trailing slash to Javascript solved my issue.
Best regards,
Timur Sufiev
  _____
From: Olivier Courtin [mailto:olivier.courtin at gmail.com]
To: mapserver-users at lists.osgeo.org
Sent: Wed, 07 Nov 2012 21:24:24 +0300
Subject: Re: [mapserver-users] [TinyOWS] Inserting feature and XML schema validation
On Wed, Nov 7, 2012 at 5:13 PM, Тимур Галиаскарович Суфиев <t.sufiev at acti.ru> wrote:
Hi Timur,
This isn't the first question here about inserting features in TinyOWS, but I haven't found solution to my problem in archives.
and this xsd should make tinyows use element '{http://www.tinyows.org}cities' like '{http://www.opengis.net/gml}_Feature'
Where am I wrong and what should be changed in my setup?
Thanks for your detailled report,
first naive question, what about the tinyows.xml config file,
 and online_resource property ?
Next question, what happen, if you bypass schema validation,
with: check_schema = "0"   (in tinyows element)
Olivier
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121116/bb80ac3f/attachment.html>
