[mapserver-users] [TinyOWS] Inserting feature and XML schema validation
Olivier Courtin olivier.courtin at gmail.com
Fri Nov 16 03:35:59 PST 2012
On Fri, Nov 16, 2012 at 12:32 PM, Тимур Галиаскарович Суфиев <
t.sufiev at acti.ru> wrote:
> I found the problem (just in case it may be useful for someone): wfs
> layers in Javascript were using
> featureNS: "http://www.tinyows.org"
> while all layers in tinyows.xml used
> ns_uri="http://www.tinyows.org/"
> Every symbol matters in deciding whether xml namespaces are the same, so
> adding trailing slash to Javascript solved my issue.
Thanks Timur to post, for the record, your own answer !
And yes as it's an URI (and not a URL) every symbol matters...
Cheers,
Olivier
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121116/839cfa01/attachment.html>
