[mapserver-users] Mapscript java 6.2
Gaston Lucero gaston.lucerom at gmail.com
Fri Nov 16 06:56:55 PST 2012
I get this error
root at Gaston:/home/gaston/mapserver-6.2.0/mapscript/java# make install
/bin/bash ../../libtool --mode=install /usr/bin/install -c
libjavamapscript.la /usr/local/lib
libtool: install: warning: relinking `libjavamapscript.la'
libtool: install: (cd /home/gaston/mapserver-6.2.0/mapscript/java;
/bin/bash /home/gaston/mapserver-6.2.0/libtool  --tag CXX --mode=relink g++
-rpath /usr/local/lib -module -release 6.2.0 -o
libjavamapscript.lajavamapscript_wrap.lo ../../
libmapserver.la )
libtool: relink: g++  -fPIC -DPIC -shared -nostdlib
/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crti.o
/usr/lib/gcc/x86_64-linux-gnu/4.7/crtbeginS.o  .libs/javamapscript_wrap.o
-L/usr/local/lib -lmapserver -L/usr/lib -lproj -ljpeg -lpng
-L/usr/lib/x86_64-linux-gnu -lgif -lgdal -lpq -lcurl -lgeos_c -lpthread
-lxml2 -ldl -lfreetype -lz -lcairo -lpng12
-L/usr/lib/gcc/x86_64-linux-gnu/4.7
-L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu
-L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../../lib -L/lib/x86_64-linux-gnu
-L/lib/../lib -L/usr/lib/../lib
-L/usr/lib/gcc/x86_64-linux-gnu/4.7/../../.. -lstdc++ -lm -lc -lgcc_s
/usr/lib/gcc/x86_64-linux-gnu/4.7/crtendS.o
/usr/lib/gcc/x86_64-linux-gnu/4.7/../../../x86_64-linux-gnu/crtn.o
 -Wl,-soname -Wl,libjavamapscript-6.2.0.so -o .libs/
/usr/bin/ld: cannot find -lmapserver
collect2: error: ld returned 1 exit status
libtool: install: error: relink `libjavamapscript.la' with the above
command before installing it
make: *** [install] Error 1
Any idea?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121116/9edd84d8/attachment-0001.html>
