[mapserver-users] [TinyOWS] Inserting feature and XML schema validation
Тимур Галиаскарович Суфиев
t.sufiev at acti.ru
Mon Nov 19 05:33:36 PST 2012
Yes, it is 1.1.0. The head commit I'm building on is
commit 4e6220b43ffd33fb649afc9c954046e7bcbe185d
Author: Olivier Courtin <olivier.courtin at oslandia.com>
Date: Wed Nov 14 01:07:34 2012 +0100
update NEWS since previous rc1
Best regards,
Timur Sufiev
_____
From: Olivier Courtin [mailto:olivier.courtin at gmail.com]
To: mapserver-users at lists.osgeo.org
Sent: Mon, 19 Nov 2012 15:48:20 +0300
Subject: Re: [mapserver-users] [TinyOWS] Inserting feature and XML schema validation
Hi Timur,
XML validation is such issue-rich subject, so I have another question considering it :).
You noticed also this one ^^
Recent TinyOWS commits (from 1st Nov till 13th, I don't know which one exactly is responsible) introduced some changes to feature ids naming, now I have the following error on features update/delete from OpenLayers:
#19 introduced that namespaces are also to be checked from Typename parameter.
(prior (wrong) behaviour was just to ignore namespace prefix)
[Mon Nov 19 16:03:30 2012] [ERROR] Element '{http://www.opengis.net/ogc}FeatureId', attribute 'fid': 'http://www.tinyows.org/:cities.719' is not a valid value of the atomic type 'xs:ID'.
Is '<ns-uri>:<layer-name>.<entity-integer-id>' a new feature-id by design or something went wrong?
Should be only <layer.name>.<entity-integer-id> (as ever)
Could you confirm that you are using current trunk version or 1.1.0 ?
Olivier
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121119/e4bc6db5/attachment.html>
