[mapserver-users] [mapserver-dev] WMS layers - using port otherthan 80
Ian Walberg
ian.walberg at airborne.aero
Tue Nov 20 09:38:14 PST 2012
Jukka,
The problem does appear to be that the GetCapabilitiesUrl is correct and the GetMapUrl and the GetFeatureInfoUrl values have the port set twice.
GetCapabilitiesUrl http://192.168.2.160:16001/cgi-bin ......
GetMapUrl http://192.168.2.160:16001:16001/cgi-bin .....
GetFeatureInfoUrl http://192.168.2.160:16001:16001/cgi-bin ...
Where do I correct this?
Not sure if this is a mapserver wms setup question or a QGIS user question.
Thanks
Ian
-----Original Message-----
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: Monday, November 19, 2012 2:04 PM
To: Ian Walberg
Cc: mapserver-dev at lists.osgeo.org; mapserver-users at lists.osgeo.org
Subject: VS: [mapserver-users] [mapserver-dev] WMS layers - using port otherthan 80
I had a try with QGIS dev. and default Geoserver installation running on localhost:8080. No trouble at all with WMS.
One thing I would check is if your Mapserver is sending correct onlineresource for including the correct port with the GetCapabilities. You can override the announced GetMap url in the QGIS WMS dialogue so that it will use the same URL as used for making the connection with QGIS but that is not the default.
-Jukka Rahkonen-
________________________________________
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] käyttäjän Ian Walberg [ian.walberg at airborne.aero] puolesta
Lähetetty: 19. marraskuuta 2012 22:39
Vastaanottaja: Ian Walberg; Stephen Woodbridge
Kopio: mapserver-dev at lists.osgeo.org; mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] [mapserver-dev] WMS layers - using port other than 80
It does seem however that QGIS does not like the wms layers to be on any port other than 80 which is where we are confused.
Ian
[mailto:mapserver-dev-bounces at lists.osgeo.org] On Behalf Of Ian Walberg
Sent: Monday, November 19, 2012 6:47 AM
To: Stephen Woodbridge
Subject: Re: [mapserver-dev] WMS layers - using port other than 80
Steve,
We finally tested this last week and unsurprisingly it was our error and everything works fine.
Thanks
Ian
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Monday, November 05, 2012 8:35 AM
To: Ian Walberg
Cc: mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
Yes, it works fine.
http://imaptools.com:8080/demo/tiger2011.html?zoom=2&lat=40.11169&lon=-9
5.18555&layers=B0
-Steve W
On 11/5/2012 10:51 AM, Ian Walberg wrote:
> Folks,
> Can anyone confirm that a WMS layer can use a port other than 80?
> From some testing we did last week it appeared that they query
> capabilities could use any port but the actual requests needed to be
> on port 80.
> Does this make sense? We will test further today to confirm.
> Thanks
> Ian
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
