[mapserver-users] Mapserver and filter in version 6
Lars-Göran Edholm lars-goran.edholm at sandviken.se
Fri Nov 23 03:03:06 PST 2012
Hi!
I have a problem with filters in Mapserver 6.
In Mapserver 5 I defined my filter as FILTER ([FNR] IN '%fasokex%') and
made a call with a new parameter like
var fastsok=210176493
http://172.20.1.218/cgi-bin/mapserv52/mapserv.exe?fasokex="+fastsok+"&map=....
layer
 metadata
  WMS_TITLE "Sökt fastighet"
  end
   #group "Grunddata"
   group "Fastigheter"
 classitem "FNR"
connectiontype ogr
connection "kartor2007/mapinfo/FASTIGHETSYTA.TAB"
    #maxscale 30000
name "fastvisa"
    status on
    type polygon
	TRANSPARENCY 40
    # 1 class Fastighetsindelning
    class
      name "Fastighetsyta"
	  #EXPRESSION ([FNR]=%fasokex%)
	  #expression '%fasokex%'
	  color 255 166 166
#SYMBOL 'circle'
OVERLAYOUTLINECOLOR 255 0 0
OVERLAYSYMBOL 'circle'
OVERLAYSIZE 12
    end
  end
Trying with the same Filter in Mapinfo 6 I cant change the filterparameter:
http://172.20.1.218/cgi-bin/mapserv6/mapserv.exe?fasokex="+fastsok+"&map=....
with
FILTER ([FNR] IN '210176493') its ok
How to write a filter in Mapserver 6 that works like in Mapserver 5 so i
can change the Filter parameter från my application
Is there something that should be added to the websection of the mapfile
or some restrictions in Apache?
Mvh
Lars-Göran Edholm    tel 026/24 14 36, telefontid dagligen 08.30-09.30
1:e byggnadsinspektör
Bygg- och miljökontoret
811 80 Sandviken
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121123/fd232525/attachment-0001.html>
