[mapserver-users] getProjection error
Bistrais, Bob
Bob.Bistrais at maine.gov
Tue Sep 4 12:12:02 PDT 2012
I have a map layer that I want to do a simple query-by-point with. Everything look OK and other, similar layers in the project work fine, but when I try to query this particular layer, I get the following error message:
Fatal error: Call to a member function getProjection() on a non-object in C:\ms4w_304\apps\basemap\htdocs\php\select.php on line 213
These are the lines of code in the php file:
$projection = $map->getProjection();
if($layer->getProjection() != NULL) {
This is the section of the .map file for the layer:
LAYER
NAME 'GeoLibrary_1ft_2003_2005'
GROUP 'GeoLibrary_1ft_2003_2005'
DATA "/mapserver_data/basemap/ortho1f/ortho1f_index.shp"
STATUS on
TYPE polygon
TRANSPARENCY 50
METADATA
"opacity" "50"
"queryable" "True"
"DESCRIPTION" "Geolibrary 1ft index"
"SEARCHFIELD" "tile"
"fields" "tile:tilename,location,link"
"hyperlink" "link"
"wms_title" "Geolibrary 1ft Index"
"wms_srs" "EPSG:26919"
'identify_record' 'templates/identify_geolib.html'
'select_record' 'templates/ortho_result.html'
'select_header' 'templates/ortho_header.html'
END
---There is a CLASS section below this for the symbology.
-As I said, other, similar layers are working just fine with the same query code, and I can't see anything wrong with the shapefile. What else should I be checking?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120904/ad9d82b6/attachment.html>
