[mapserver-users] getProjection error
Jeff McKenna jmckenna at gatewaygeomatics.com
Wed Sep 5 06:35:20 PDT 2012
On 12-09-04 4:12 PM, Bistrais, Bob wrote:
> -As I said, other, similar layers are working just fine with the same
> query code, and I can’t see anything wrong with the shapefile.  What
> else should I be checking?
Hmm I am not sure.  What exact line is 213? If I was going to use a
getProjection() function I would make sure that each LAYER has a
PROJECTION object in the mapfile (as well as in the MAP object).
Maybe other list readers can see the issue.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
