[mapserver-users] [TINYOWS] 'Looser' XSD?
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Sep 7 07:57:55 PDT 2012
Eric,
Thanks for reporting this because I have to dive into doing the same
shortly.
I would suggest that OpenLayers is where the problem is because it is
generating the XML that is going to TinyOWS. I have not looked into this
specific issue but in general OL is pretty flexible and you might only
need to set the appropriate namespace or GML level in OL to fix this
problem. I would check with that list first.
Thanks,
-Steve
On 9/7/2012 1:08 AM, Eric wrote:
> Hello list,
> I am trying to save features to a PostGIS DB using tinyows. Saving
> geometries alone works fine, updating records works well, but as soon as
> I combine attributes and geometries, I get an error from tinyows
> indicating that the XML is not in the right format. I have noticed a
> difference between the 3 scenarios. For instance, when I save a geometry
> without attributes, I get the following: (this works fine)
> <wfs:Insert>
> <feature:parcels xmlns:feature="http://www.tinyows.org/">
> <feature:geom>
> <gml:MultiSurface xmlns:gml="http://www.opengis.net/gml" srsName="EPSG:3857">
> <gml:surfaceMember>
> <gml:Polygon>
> <gml:exterior>
> <gml:LinearRing>
> <gml:posList>-10752.....</gml:posList>
> </gml:LinearRing>
> </gml:exterior>
> </gml:Polygon>
> </gml:surfaceMember>
> </gml:MultiSurface>
> </feature:geom>
> </feature:washco_parcels>
> </wfs:Insert>
> And, when I add attributes, I get the following: (generates an error to
> teh effect that "<feature:address1>test" is unexpected)
> <wfs:Insert>
> <feature:geom>
> <gml:surfaceMember>
> <gml:Polygon>
> <gml:exterior>
> <gml:LinearRing>
> </gml:LinearRing>
> </gml:exterior>
> </gml:Polygon>
> </gml:MultiSurface>
> </feature:geom>
> *<feature:address1>test</feature:address1>*
> </wfs:Insert>
> Finally, if I do a simple UPDATE, I get the following: (works fine)
> <wfs:Update xmlns:demo="http://www.tinyows.org/" typeName="demo:parcels">
> <wfs:Property>
> <wfs:Name>geom</wfs:Name>
> <wfs:Value>
> <gml:surfaceMember>
> <gml:Polygon>
> <gml:exterior>
> <gml:LinearRing>
> <gml:posList>-10737.....</gml:posList>
> </gml:LinearRing>
> </gml:exterior>
> </gml:Polygon>
> </gml:MultiSurface>
> </wfs:Value>
> </wfs:Property>
> *<wfs:Property>
> <wfs:Name>objectid</wfs:Name>
> <wfs:Value>18785</wfs:Value>
> </wfs:Property>*
> The first difference is in the namespace used (feature vs wfs). Any
> reason why it is doing so? Another difference is in the way attributes
> are included:
> <wfs:Property>
> </wfs:Property>
> vs
> The third example (using wfs:Property) seems to be the correct way to
> specify information in a WFS file. The first example works fine despite
> not using that format, because I suspect the GML schema is more flexible
> and since it does not have attributes that are not geometries, it is
> considered valid.
> So I tried turning off schema checking in the tinyows.xml file and the
> problem payload go through without issues. So this seem to indicate that
> some of the XSD used are strict and don't allow attributes to be defined
> like <feature:address1>test</feature:address1>.
> So my question is how do I fix this best?
> 1. remove schema enforcing at the tinyows level. Couldn't this lead to
> potential security issues with the server?
> 2. Change the XSD files to allow both ways to define attributes.
> Wouldn't this go against the WFS standard?
> 3. Change the way OL generates the payload. Not sure where it does it
> or how to force it to use a different one.
> BTW, I am using OL 2.12 and Tinyows 1.0.0
> thanks!
> Eric
> mapserver-users at lists.osgeo.org
