[mapserver-users] [TINYOWS] 'Looser' XSD?
Eric
eric at glimpsely.com
Fri Sep 7 10:13:20 PDT 2012
Indeed, it appears it should be straightforward to resolve this from the
OL end.
I have just summoned the help of the "OpenLayers-User mailing list"
gurus about this. Refer to the thread over there for further information.
Thanks,
Eric
On 09/07/2012 11:57 AM, Stephen Woodbridge wrote:
> Eric,
> Thanks for reporting this because I have to dive into doing the same
> shortly.
> I would suggest that OpenLayers is where the problem is because it is
> generating the XML that is going to TinyOWS. I have not looked into
> this specific issue but in general OL is pretty flexible and you might
> only need to set the appropriate namespace or GML level in OL to fix
> this problem. I would check with that list first.
> Thanks,
> -Steve
> On 9/7/2012 1:08 AM, Eric wrote:
>> Hello list,
>> I am trying to save features to a PostGIS DB using tinyows. Saving
>> geometries alone works fine, updating records works well, but as soon as
>> I combine attributes and geometries, I get an error from tinyows
>> indicating that the XML is not in the right format. I have noticed a
>> difference between the 3 scenarios. For instance, when I save a geometry
>> without attributes, I get the following: (this works fine)
>> <wfs:Insert>
>> <feature:parcels xmlns:feature="http://www.tinyows.org/">
>> <feature:geom>
>> <gml:MultiSurface xmlns:gml="http://www.opengis.net/gml"
>> srsName="EPSG:3857">
>> <gml:surfaceMember>
>> <gml:Polygon>
>> <gml:exterior>
>> <gml:LinearRing>
>> <gml:posList>-10752.....</gml:posList>
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:Polygon>
>> </gml:surfaceMember>
>> </gml:MultiSurface>
>> </feature:geom>
>> </feature:washco_parcels>
>> </wfs:Insert>
>> And, when I add attributes, I get the following: (generates an error to
>> teh effect that "<feature:address1>test" is unexpected)
>> <wfs:Insert>
>> <feature:geom>
>> <gml:surfaceMember>
>> <gml:Polygon>
>> <gml:exterior>
>> <gml:LinearRing>
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:Polygon>
>> </gml:MultiSurface>
>> </feature:geom>
>> *<feature:address1>test</feature:address1>*
>> </wfs:Insert>
>> Finally, if I do a simple UPDATE, I get the following: (works fine)
>> <wfs:Update xmlns:demo="http://www.tinyows.org/"
>> typeName="demo:parcels">
>> <wfs:Property>
>> <wfs:Name>geom</wfs:Name>
>> <wfs:Value>
>> <gml:surfaceMember>
>> <gml:Polygon>
>> <gml:exterior>
>> <gml:LinearRing>
>> <gml:posList>-10737.....</gml:posList>
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:Polygon>
>> </gml:MultiSurface>
>> </wfs:Value>
>> </wfs:Property>
>> *<wfs:Property>
>> <wfs:Name>objectid</wfs:Name>
>> <wfs:Value>18785</wfs:Value>
>> </wfs:Property>*
>> The first difference is in the namespace used (feature vs wfs). Any
>> reason why it is doing so? Another difference is in the way attributes
>> are included:
>> <wfs:Property>
>> </wfs:Property>
>> vs
>> The third example (using wfs:Property) seems to be the correct way to
>> specify information in a WFS file. The first example works fine despite
>> not using that format, because I suspect the GML schema is more flexible
>> and since it does not have attributes that are not geometries, it is
>> considered valid.
>> So I tried turning off schema checking in the tinyows.xml file and the
>> problem payload go through without issues. So this seem to indicate that
>> some of the XSD used are strict and don't allow attributes to be defined
>> like <feature:address1>test</feature:address1>.
>> So my question is how do I fix this best?
>> 1. remove schema enforcing at the tinyows level. Couldn't this lead to
>> potential security issues with the server?
>> 2. Change the XSD files to allow both ways to define attributes.
>> Wouldn't this go against the WFS standard?
>> 3. Change the way OL generates the payload. Not sure where it does it
>> or how to force it to use a different one.
>> BTW, I am using OL 2.12 and Tinyows 1.0.0
>> thanks!
>> Eric
