[mapserver-users] mapserver+javascript without template example?!!!
Saka Royban sakaroyban at yahoo.com
Sun Sep 9 22:46:25 PDT 2012
Thanks for your help
I changed my file to follows:
</head>
    <script language="JavaScript">
        function zoom(){
            document.forms['mapserv'].submit();
    </script>
<body>
<h1> A Dynamic Map </h1>
<p></p>
<h3> use form to make map dynamic + scripting </h3>
    <form name="mapserv" method="get" action="/cgi-bin/mapserv.exe">
        <input type="hidden" name="imgxy" value="[center]">
        <input type="hidden" name="map" value="[map]" />
        <input type="hidden" name="imgext" value="[mapext]" />
        <input type="hidden" name="layers" value="[layers]" />
        <input type="hidden" name="mode" value="map" />
        <input type="hidden" name="zoomsize" value="2" />
        <input type="image" name="img" src="http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/ms101/htdocs/ms101.map&layers=all&mode=map"  onclick="zoom()"/>
    </form>
</body>
<html>
If i click on image, i get a response from mapserver correctly. In fact, in loading the above page, mapserver properly fills variables like [map]. This is the url after clicking map:
http://localhost/cgi-bin/mapserv.exe?imgxy=400+200&map=%2Fms4w%2Fapps%2Fms101%2Fhtdocs%2Fms101.map&imgext=-180+-90+180+90&layers=[layers]&mode=map&zoomsize=2&img.x=228&img.y=108
But when i remove <input type="hidden" name="imgxy" value="[center]">, mapserver does not substitutes any variable.
this is the url after clicking map:
http://localhost/cgi-bin/mapserv.exe?map=[map]&imgext=[mapext]&layers=[layers]&mode=map&zoomsize=2&img.x=618&img.y=160
Why MapServer behaves like this? (useful for mentioning, there is no template defined in map file)
----- Original Message -----
From: Alan Boudreault <aboudreault at mapgears.com>
To: mapserver-users at lists.osgeo.org
Cc:
Sent: Monday, September 10, 2012 5:58 AM
Subject: Re: [mapserver-users] mapserver+javascript without template example?!!!
You should verify what exact request is sent to the server... I would
assume something like "map=[map]" is sent. Use Firebug of any other
debugging tool.
Alan
On 12-09-09 01:54 PM, Saka Royban wrote:
> Hi all.
> I'm just looking for some examples of using javascript with mapserver
> without using html templates.
> I know that there are some libraries around like OpenLayers, but i wanna
> see what happens in background first and then move to use these libraries.
> This is what i have written which does not works: (i get a error saying
> MS_DEFAULT_MAPFILE_PATTERN validation failed )
> <html>
> <head>
> </head>
>          function zoom(){
>          document.forms['mapserv'].imgxy.value = "400 200";
>          document.forms['mapserv'].zoom.value = 2;
>      </script>
> <body>
> <p></p>
>      <form name="mapserv" method="GET" action="/cgi-bin/mapserv.exe">
>          <input type="hidden" name="imgxy" value="400 200">
>          <input type="hidden" name="imgxy" value="[center]" />
> onclick="zoom()"/>
>      </form>
> </body>
> Thanks in advance
> <html>
Alan Boudreault
http://www.mapgears.com/
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120909/16e91f6b/attachment.html>
