[mapserver-users] mapserver+javascript without template example?!!!
Alan Boudreault
aboudreault at mapgears.com
Mon Sep 10 04:46:02 PDT 2012
This is not related to mapserver. This is only html/form. There is no
*substitution* of mapserver at all with this example.
Take a look at this documentation about html form:
http://www.w3.org/TR/html401/interact/forms.html
Also, the reason why imxy input has some effect on the url sent is
because it is missing its "end tag". See "value="[center]">" rather than
"value="[center]"/>"
Good Luck!
Alan
On 12-09-10 01:46 AM, Saka Royban wrote:
> Thanks for your help
> I changed my file to follows:
> </head>
> <script language="JavaScript">
> function zoom(){
> document.forms['mapserv'].submit();
> </script>
> <body>
> <h1> A Dynamic Map </h1>
> <p></p>
> <h3> use form to make map dynamic + scripting </h3>
> <form name="mapserv" method="get" action="/cgi-bin/mapserv.exe">
> <input type="hidden" name="imgxy" value="[center]">
> <input type="hidden" name="map" value="[map]" />
> <input type="hidden" name="imgext" value="[mapext]" />
> <input type="hidden" name="layers" value="[layers]" />
> <input type="hidden" name="mode" value="map" />
> <input type="hidden" name="zoomsize" value="2" />
> <input type="image" name="img"
> src="http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/ms101/htdocs/ms101.map&layers=all&mode=map"
> onclick="zoom()"/>
> </form>
> </body>
> <html>
> If i click on image, i get a response from mapserver correctly. In fact,
> in loading the above page, mapserver properly fills variables like
> [map]. This is the url after clicking map:
> http://localhost/cgi-bin/mapserv.exe?imgxy=400+200&map=%2Fms4w%2Fapps%2Fms101%2Fhtdocs%2Fms101.map&imgext=-180+-90+180+90&layers=[layers]&mode=map&zoomsize=2&img.x=228&img.y=108
> But when i remove <input type="hidden" name="imgxy" value="[center]">,
> mapserver does not substitutes any variable.
> this is the url after clicking map:
> http://localhost/cgi-bin/mapserv.exe?map=[map]&imgext=[mapext]&layers=[layers]&mode=map&zoomsize=2&img.x=618&img.y=160
> Why MapServer behaves like this? (useful for mentioning, there is no
> template defined in map file)
> ----- Original Message -----
> From: Alan Boudreault <aboudreault at mapgears.com>
> To: mapserver-users at lists.osgeo.org
> Cc:
> Sent: Monday, September 10, 2012 5:58 AM
> Subject: Re: [mapserver-users] mapserver+javascript without template
> example?!!!
> You should verify what exact request is sent to the server... I would
> assume something like "map=[map]" is sent. Use Firebug of any other
> debugging tool.
> Alan
> On 12-09-09 01:54 PM, Saka Royban wrote:
> > Hi all.
> > I'm just looking for some examples of using javascript with mapserver
> > without using html templates.
> > I know that there are some libraries around like OpenLayers, but i wanna
> > see what happens in background first and then move to use these
> libraries.
> > This is what i have written which does not works: (i get a error saying
> > MS_DEFAULT_MAPFILE_PATTERN validation failed )
> > <html>
> > <head>
> > </head>
> > function zoom(){
> > document.forms['mapserv'].imgxy.value = "400 200";
> > document.forms['mapserv'].zoom.value = 2;
> > </script>
> > <body>
> > <p></p>
> > <form name="mapserv" method="GET" action="/cgi-bin/mapserv.exe">
> > <input type="hidden" name="imgxy" value="400 200">
> > <input type="hidden" name="imgxy" value="[center]" />
> > onclick="zoom()"/>
> > </form>
> > </body>
> > Thanks in advance
> > <html>
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Alan Boudreault
> http://www.mapgears.com/
Alan Boudreault
