[mapserver-users] problem using sld stroke-opacity
Oliver Christen
oliver.christen at camptocamp.com
Mon Sep 10 08:41:50 PDT 2012
dear list
I am trying to use sld to stylize the map in a project and Im having
some problem with stroke-opacity, I dont see any visible change whatever
value I set.
the sld is there:
http://dev.camptocamp.com/files/mapserver/sld_line_width.xml
I have tried with the mapserver demo too, same result:
http://demo.mapserver.org/cgi-bin/wms?SERVICE=wms&VERSION=1.1.1&REQUEST=GetMap&LAYERS=country_bounds&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://dev.camptocamp.com/files/mapserver/sld_line_width.xml
did I do something wrong or forgot to set something in the sld to have
it to work correctly?
Im using mapserver 6.0.3
thank you for reading, any help will be greatly appreciated
best regards
Oliver
Camptocamp SA
Oliver Christen
PSE A
CH-1015 Lausanne
www.camptocamp.com
+41 21 619 10 23 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
