[mapserver-users] problem using sld stroke-opacity
Oliver Christen oliver.christen at camptocamp.com
Mon Sep 10 08:46:34 PDT 2012
ah nevemind, I found the related bug entry:
https://github.com/mapserver/mapserver/issues/4132
so it would be ok in the next 6.2 release :)
> dear list
> I am trying to use sld to stylize the map in a project and Im having
> some problem with stroke-opacity, I dont see any visible change
> whatever value I set.
> the sld is there:
> http://dev.camptocamp.com/files/mapserver/sld_line_width.xml
> I have tried with the mapserver demo too, same result:
> http://demo.mapserver.org/cgi-bin/wms?SERVICE=wms&VERSION=1.1.1&REQUEST=GetMap&LAYERS=country_bounds&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=http://dev.camptocamp.com/files/mapserver/sld_line_width.xml
> did I do something wrong or forgot to set something in the sld to have
> it to work correctly?
> Im using mapserver 6.0.3
> thank you for reading, any help will be greatly appreciated
> best regards
> Oliver
Camptocamp SA
Oliver Christen
PSE A
CH-1015 Lausanne
www.camptocamp.com
+41 21 619 10 23 (direct)
+41 21 619 10 10 (centrale)
+41 21 619 10 00 (fax)
