[mapserver-users] mapserver as a wms server for arcgis client
pcreso at pcreso.com
Thu Sep 13 10:44:32 PDT 2012
Can you confirm it works OK with other clients, like QGIS?
I generally use QGIS for testing, as I can easily & simultaneously open the shapefiles, imagery, postgis tables, etc as well as the WMS/WFS outputs to ensure all is doing exactly what it should.
We are using mapserver to provide layers to clients using ESRI so it does work.
I would also note that mapserver 5.2 is a bit dated now, & wms v1.3.0 is the current version which you do not show support for.
Brent Wood
--- On Thu, 9/13/12, Jessica Clarke <Jessica.Clarke at forestrytas.com.au> wrote:
From: Jessica Clarke <Jessica.Clarke at forestrytas.com.au>
Subject: [mapserver-users] mapserver as a wms server for arcgis client
To: mapserver-users at lists.osgeo.org
Date: Thursday, September 13, 2012, 6:53 PM
I'm hoping someone can help me identify why my wms layers in arcgis are coming up blank.
Here is my mapfile:
MAP
NAME "WMSQuick"
STATUS ON
EXTENT 227154 5165779 627108 5614539
UNITS DD
SHAPEPATH "c:/images"
SIZE 800 600
PROJECTION
"init=epsg:28355"
END
OUTPUTFORMAT
NAME 'AGG/PNG'
DRIVER AGG/PNG
END
WEB
IMAGEPATH "C:/images/"
IMAGEURL "/images/"
METADATA
"wms_title" "WMS Demo" ##required
"wms_onlineresource" "http://test/cgi-bin/mapserv.exe?map=E:\mapfiles\wmstest4.map&"
"wms_enable_request" "*" ##necessary
"wms_server_version" "1.1.1"
"wms_extent" "227154 5165779 627108 5614539"
END
END
LAYER
NAME "AdminCountries"
STATUS ON
TYPE POLYGON
DATA "img_index.shp"
CLASS
STYLE
COLOR 246 241 223
OUTLINECOLOR 0 0 0
END
END
METADATA
"wms_title" "admin_countries"
"wms_name" "admincountries"
#"wms_extent" "227154 5165779 627108 5614539"
"wms_format" "image/tif"
END
PROJECTION
"init=epsg:28355"
END
END
LEGEND
KEYSIZE 12 12
STATUS EMBED
POSITION lr
IMAGECOLOR 125 125 125
LABEL
COLOR 255 255 255
FONT "verdana"
TYPE TRUETYPE
POSITION AUTO
PARTIALS FALSE
SIZE 8
BUFFER 1
END
END
END
Here is my capabilities report:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
<WMT_MS_Capabilities version="1.1.1">
<!-- MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
<Name>OGC:WMS</Name>
<Title>WMS Demo</Title>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://test/cgi-bin/mapserv.exe?map=E:\mapfiles\wmstest4.map&"/>
</Service>
<Capability>
<Request>
<GetCapabilities>
<Format>application/vnd.ogc.wms_xml</Format>
<DCPType>
<HTTP>
<Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://test/cgi-bin/mapserv.exe?map=E:\mapfiles\wmstest4.map&"/></Get>
<Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://test/cgi-bin/mapserv.exe?map=E:\mapfiles\wmstest4.map&"/></Post>
</HTTP>
</DCPType>
</GetCapabilities>
<GetMap>
<Format>image/gif</Format>
<Format>image/png</Format>
<Format>image/png; mode=24bit</Format>
<Format>image/jpeg</Format>
<Format>image/vnd.wap.wbmp</Format>
<Format>image/tiff</Format>
<Format>image/svg+xml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetMap>
<GetFeatureInfo>
<Format>text/plain</Format>
<Format>application/vnd.ogc.gml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetFeatureInfo>
<DescribeLayer>
<Format>text/xml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</DescribeLayer>
<GetLegendGraphic>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetLegendGraphic>
<GetStyles>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetStyles>
</Request>
<Exception>
<Format>application/vnd.ogc.se_xml</Format>
<Format>application/vnd.ogc.se_inimage</Format>
<Format>application/vnd.ogc.se_blank</Format>
</Exception>
<VendorSpecificCapabilities />
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
<Layer>
<Name>WMSQuick</Name>
<SRS>EPSG:28355</SRS>
<LatLonBoundingBox minx="143.619" miny="-43.661" maxx="148.576" maxy="-39.5755" />
<BoundingBox SRS="EPSG:28355"
minx="227154" miny="5.16578e+006" maxx="627108" maxy="5.61454e+006" />
<Layer queryable="0" opaque="0" cascaded="0">
<Name>AdminCountries</Name>
<Title>admin_countries</Title>
<LatLonBoundingBox minx="146.276" miny="-42.7217" maxx="146.522" maxy="-41.3319" />
minx="440755" miny="5.26997e+006" maxx="460030" maxy="5.42416e+006" />
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
Am I missing something vital? I am able to add the WMS layers in arcmap, but the canvas is blank.
Thanks in advance.
Jess
-----Inline Attachment Follows-----
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120913/579952ea/attachment-0001.html>
