[mapserver-users] mapserver as a wms server for arcgis client
Robert Sanson
Robert.Sanson at asurequality.com
Thu Sep 13 10:51:14 PDT 2012
Hi Jessica
I can confirm with Brent that ArcMap can read WMS layers from Mapserver. You need to specify the version in ArcCatalog when you first connect, otherwise ArcMap will try v1.3 by default (from memory).
Regards,
Robert
>>> <pcreso at pcreso.com> 14/09/2012 5:44 a.m. >>>
Can you confirm it works OK with other clients, like QGIS?
I generally use QGIS for testing, as I can easily & simultaneously open the shapefiles, imagery, postgis tables, etc as well as the WMS/WFS outputs to ensure all is doing exactly what it should.
We are using mapserver to provide layers to clients using ESRI so it does work.
I would also note that mapserver 5.2 is a bit dated now, & wms v1.3.0 is the current version which you do not show support for.
Brent Wood
--- On Thu, 9/13/12, Jessica Clarke <Jessica.Clarke at forestrytas.com.au> wrote:
From: Jessica Clarke <Jessica.Clarke at forestrytas.com.au>
Subject: [mapserver-users] mapserver as a wms server for arcgis client
To: mapserver-users at lists.osgeo.org
Date: Thursday, September 13, 2012, 6:53 PM
I'm hoping someone can help me identify why my wms layers in arcgis are coming up blank.
Here is my mapfile:
MAP
NAME "WMSQuick"
STATUS ON
EXTENT 227154 5165779 627108 5614539
UNITS DD
SHAPEPATH "c:/images"
SIZE 800 600
PROJECTION
"init=epsg:28355"
END
OUTPUTFORMAT
NAME 'AGG/PNG'
DRIVER AGG/PNG
END
WEB
IMAGEPATH "C:/images/"
IMAGEURL "/images/"
METADATA
"wms_title" "WMS Demo" ##required
"wms_onlineresource" "http://test/cgi-bin/mapserv.exe?map=E:\mapfiles\wmstest4.map&"
"wms_enable_request" "*" ##necessary
"wms_server_version" "1.1.1"
"wms_extent" "227154 5165779 627108 5614539"
END
END
LAYER
NAME "AdminCountries"
STATUS ON
TYPE POLYGON
DATA "img_index.shp"
CLASS
STYLE
COLOR 246 241 223
OUTLINECOLOR 0 0 0
END
END
METADATA
"wms_title" "admin_countries"
"wms_name" "admincountries"
#"wms_extent" "227154 5165779 627108 5614539"
"wms_format" "image/tif"
END
PROJECTION
"init=epsg:28355"
END
END
LEGEND
KEYSIZE 12 12
STATUS EMBED
POSITION lr
IMAGECOLOR 125 125 125
LABEL
COLOR 255 255 255
FONT "verdana"
TYPE TRUETYPE
POSITION AUTO
PARTIALS FALSE
SIZE 8
BUFFER 1
END
END
END
Here is my capabilities report:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE WMT_MS_Capabilities SYSTEM "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
<!ELEMENT VendorSpecificCapabilities EMPTY>
]> <!-- end of DOCTYPE declaration -->
<WMT_MS_Capabilities version="1.1.1">
<!-- MapServer version 5.2.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE -->
<Service>
<Name>OGC:WMS</Name>
<Title>WMS Demo</Title>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://test/cgi-bin/mapserv.exe?map=E:\mapfiles\wmstest4.map&"/>
</Service>
<Capability>
<Request>
<GetCapabilities>
<Format>application/vnd.ogc.wms_xml</Format>
<DCPType>
<HTTP>
<Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://test/cgi-bin/mapserv.exe?map=E:\mapfiles\wmstest4.map&"/></Get>
<Post><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://test/cgi-bin/mapserv.exe?map=E:\mapfiles\wmstest4.map&"/></Post>
</HTTP>
</DCPType>
</GetCapabilities>
<GetMap>
<Format>image/gif</Format>
<Format>image/png</Format>
<Format>image/png; mode=24bit</Format>
<Format>image/jpeg</Format>
<Format>image/vnd.wap.wbmp</Format>
<Format>image/tiff</Format>
<Format>image/svg+xml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetMap>
<GetFeatureInfo>
<Format>text/plain</Format>
<Format>application/vnd.ogc.gml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetFeatureInfo>
<DescribeLayer>
<Format>text/xml</Format>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</DescribeLayer>
<GetLegendGraphic>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetLegendGraphic>
<GetStyles>
<DCPType>
<HTTP>
</HTTP>
</DCPType>
</GetStyles>
</Request>
<Exception>
<Format>application/vnd.ogc.se_xml</Format>
<Format>application/vnd.ogc.se_inimage</Format>
<Format>application/vnd.ogc.se_blank</Format>
</Exception>
<VendorSpecificCapabilities />
<UserDefinedSymbolization SupportSLD="1" UserLayer="0" UserStyle="1" RemoteWFS="0"/>
<Layer>
<Name>WMSQuick</Name>
<SRS>EPSG:28355</SRS>
<LatLonBoundingBox minx="143.619" miny="-43.661" maxx="148.576" maxy="-39.5755" />
<BoundingBox SRS="EPSG:28355"
minx="227154" miny="5.16578e+006" maxx="627108" maxy="5.61454e+006" />
<Layer queryable="0" opaque="0" cascaded="0">
<Name>AdminCountries</Name>
<Title>admin_countries</Title>
<LatLonBoundingBox minx="146.276" miny="-42.7217" maxx="146.522" maxy="-41.3319" />
minx="440755" miny="5.26997e+006" maxx="460030" maxy="5.42416e+006" />
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
Am I missing something vital? I am able to add the WMS layers in arcmap, but the canvas is blank.
Thanks in advance.
Jess
-----Inline Attachment Follows-----
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
This message has been scanned for Malware and Viruses by Websense Hosted Security.
www.websense.com
