[mapserver-users] MapServer 6.2.0 beta2 release - WFS getcapabilities problem
Helen San Segundo Navazo hsansegundo at meteo.cat
Wed Sep 26 07:20:31 PDT 2012
ok, on my setup, getcapabilities on wfs_simple.map:
-mapserver 6.2:   fails : Service=WFS&Version=1.1.0&Request=Getcapabilities
                             works :
Service=WFS&Version=1.0.0&Request=Getcapabilities
-mapserver 6.0.2:   works :
                                 works :
thanks,
Helen
El 26/09/12 16:06, thomas bonfort escribió:
> On Wed, Sep 26, 2012 at 3:56 PM, Helen San Segundo Navazo
> <hsansegundo at meteo.cat>  wrote:
>> Hi, I've download the mapserver-msautotest-970b31e and I've done the
>> getcapabilities request to the wfs_simple.map in both versions of mapserver
>> and the result is the same, with the 6.0.2 I have no problem but with
>> mapserver 6.2 beta2, wfs 1.1.0 not works.
> to clarify, on your setup, getcapabilities on wfs_simple.map fails
> with 6.2 and succeeds in 6.0.2 ?
>> this is the mapservers installation I have:
>> MapServer version 6.2.0-beta2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=ORACLESPATIAL
>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>   MapServer version 6.0.2   OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR
>> El 26/09/12 14:21, thomas bonfort escribió:
>>> Sorry, not able to test this as the mapfile is missing some includes,
>>> and I am not setup to test oracle connections. please test this with a
>>> shapefile mapfile, and/or give more info as to what output you're
>>> getting on the failed request (no output at all, error message, ... ?)
>>> On Wed, Sep 26, 2012 at 2:07 PM, Helen San Segundo Navazo
>>>> Hi,
>>>> I send you the map file.
>>>> Thanks,
>>>> Helen
>>>> El 26/09/12 13:49, thomas bonfort escribió:
>>>>> Helen,
>>>>> can you provide the mapfile you are using that exhibits this? Our
>>>>> tests on wfs capabilities show no abnormal failures between 1.0.0 and
>>>>> 1.1.0 getcaps requests:
>>>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs11_cap.xml
>>>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs_cap.xml
>>>>> thomas
>>>>> On Wed, Sep 26, 2012 at 1:32 PM, Helen San Segundo Navazo
>>>>>> Hi to all,
>>>>>> I've created some wfs on mapserver 6.0.2 and all of them work perfectly
>>>>>> with
>>>>>> the different requests and wfs versions 1.0.0 and 1.1.0.
>>>>>> I've pass from 6.0.2 to 6.2.0 beta2 release to solve the style request
>>>>>> problem with raster data sources and now I have problems with the wfs
>>>>>> getcapabilities request with 1.1.0 version.
>>>>>> With this 1.1.0 version I can't do getcapabilities request, I have no
>>>>>> response but there is no problem with describefeaturetype or getfeature
>>>>>> requests.
>>>>>> With the same 6.2.0 beta2 if I use wfs version= 1.0.0 there is no
>>>>>> problem.
>>>>>> Anybody knows wich can be the problem?
>>>>>> Thanks
>>>>>> _______________________________________________
>>>>>> mapserver-users mailing list
>>>>>> mapserver-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
