[mapserver-users] MapServer 6.2.0 beta2 release - WFS getcapabilities problem
thomas bonfort
thomas.bonfort at gmail.com
Wed Sep 26 07:31:39 PDT 2012
ok, can try beta3, or even better the branch-6-2 from github (zip
download from https://github.com/mapserver/mapserver/zipball/branch-6-2
On Wed, Sep 26, 2012 at 4:20 PM, Helen San Segundo Navazo
<hsansegundo at meteo.cat> wrote:
> ok, on my setup, getcapabilities on wfs_simple.map:
> -mapserver 6.2: fails : Service=WFS&Version=1.1.0&Request=Getcapabilities
> works :
> Service=WFS&Version=1.0.0&Request=Getcapabilities
> -mapserver 6.0.2: works :
> works :
> thanks,
> Helen
> El 26/09/12 16:06, thomas bonfort escribió:
>> On Wed, Sep 26, 2012 at 3:56 PM, Helen San Segundo Navazo
>>> Hi, I've download the mapserver-msautotest-970b31e and I've done the
>>> getcapabilities request to the wfs_simple.map in both versions of
>>> mapserver
>>> and the result is the same, with the 6.0.2 I have no problem but with
>>> mapserver 6.2 beta2, wfs 1.1.0 not works.
>> to clarify, on your setup, getcapabilities on wfs_simple.map fails
>> with 6.2 and succeeds in 6.0.2 ?
>>> this is the mapservers installation I have:
>>> MapServer version 6.2.0-beta2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>> OUTPUT=KML
>>> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>>> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>> SUPPORTS=WFS_SERVER
>>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>>> SUPPORTS=FASTCGI
>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
>>> INPUT=ORACLESPATIAL
>>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>> MapServer version 6.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE
>>> SUPPORTS=ICONV
>>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>>> SUPPORTS=FASTCGI
>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=ORACLESPATIAL
>>> INPUT=OGR
>>> El 26/09/12 14:21, thomas bonfort escribió:
>>>> Sorry, not able to test this as the mapfile is missing some includes,
>>>> and I am not setup to test oracle connections. please test this with a
>>>> shapefile mapfile, and/or give more info as to what output you're
>>>> getting on the failed request (no output at all, error message, ... ?)
>>>> On Wed, Sep 26, 2012 at 2:07 PM, Helen San Segundo Navazo
>>>>> Hi,
>>>>> I send you the map file.
>>>>> Thanks,
>>>>> Helen
>>>>> El 26/09/12 13:49, thomas bonfort escribió:
>>>>>> Helen,
>>>>>> can you provide the mapfile you are using that exhibits this? Our
>>>>>> tests on wfs capabilities show no abnormal failures between 1.0.0 and
>>>>>> 1.1.0 getcaps requests:
>>>>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs11_cap.xml
>>>>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs_cap.xml
>>>>>> thomas
>>>>>> On Wed, Sep 26, 2012 at 1:32 PM, Helen San Segundo Navazo
>>>>>>> Hi to all,
>>>>>>> I've created some wfs on mapserver 6.0.2 and all of them work
>>>>>>> perfectly
>>>>>>> with
>>>>>>> the different requests and wfs versions 1.0.0 and 1.1.0.
>>>>>>> I've pass from 6.0.2 to 6.2.0 beta2 release to solve the style
>>>>>>> request
>>>>>>> problem with raster data sources and now I have problems with the wfs
>>>>>>> getcapabilities request with 1.1.0 version.
>>>>>>> With this 1.1.0 version I can't do getcapabilities request, I have no
>>>>>>> response but there is no problem with describefeaturetype or
>>>>>>> getfeature
>>>>>>> requests.
>>>>>>> With the same 6.2.0 beta2 if I use wfs version= 1.0.0 there is no
>>>>>>> problem.
>>>>>>> Anybody knows wich can be the problem?
>>>>>>> Thanks
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
