[mapserver-users] MapServer 6.2.0 beta2 release - WFS getcapabilities problem
Helen San Segundo Navazo hsansegundo at meteo.cat
Thu Sep 27 00:25:14 PDT 2012
ok, thanks
El 26/09/12 16:31, thomas bonfort escribió:
> ok, can try beta3, or even better the branch-6-2 from github (zip
> download from https://github.com/mapserver/mapserver/zipball/branch-6-2
> On Wed, Sep 26, 2012 at 4:20 PM, Helen San Segundo Navazo
> <hsansegundo at meteo.cat>  wrote:
>> ok, on my setup, getcapabilities on wfs_simple.map:
>> -mapserver 6.2:   fails : Service=WFS&Version=1.1.0&Request=Getcapabilities
>>                              works :
>> Service=WFS&Version=1.0.0&Request=Getcapabilities
>> -mapserver 6.0.2:   works :
>>                                  works :
>> thanks,
>> Helen
>> El 26/09/12 16:06, thomas bonfort escribió:
>>> On Wed, Sep 26, 2012 at 3:56 PM, Helen San Segundo Navazo
>>>> Hi, I've download the mapserver-msautotest-970b31e and I've done the
>>>> getcapabilities request to the wfs_simple.map in both versions of
>>>> mapserver
>>>> and the result is the same, with the 6.0.2 I have no problem but with
>>>> mapserver 6.2 beta2, wfs 1.1.0 not works.
>>> to clarify, on your setup, getcapabilities on wfs_simple.map fails
>>> with 6.2 and succeeds in 6.0.2 ?
>>>> this is the mapservers installation I have:
>>>> MapServer version 6.2.0-beta2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
>>>> OUTPUT=KML
>>>> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
>>>> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>>> SUPPORTS=WFS_SERVER
>>>> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
>>>> SUPPORTS=FASTCGI
>>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS
>>>> INPUT=ORACLESPATIAL
>>>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>>>    MapServer version 6.0.2   OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>>>> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE
>>>> SUPPORTS=ICONV
>>>> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>>>> SUPPORTS=FASTCGI
>>>> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=ORACLESPATIAL
>>>> INPUT=OGR
>>>> El 26/09/12 14:21, thomas bonfort escribió:
>>>>> Sorry, not able to test this as the mapfile is missing some includes,
>>>>> and I am not setup to test oracle connections. please test this with a
>>>>> shapefile mapfile, and/or give more info as to what output you're
>>>>> getting on the failed request (no output at all, error message, ... ?)
>>>>> On Wed, Sep 26, 2012 at 2:07 PM, Helen San Segundo Navazo
>>>>>> Hi,
>>>>>> I send you the map file.
>>>>>> Thanks,
>>>>>> Helen
>>>>>> El 26/09/12 13:49, thomas bonfort escribió:
>>>>>>> Helen,
>>>>>>> can you provide the mapfile you are using that exhibits this? Our
>>>>>>> tests on wfs capabilities show no abnormal failures between 1.0.0 and
>>>>>>> 1.1.0 getcaps requests:
>>>>>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs11_cap.xml
>>>>>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs_cap.xml
>>>>>>> thomas
>>>>>>> On Wed, Sep 26, 2012 at 1:32 PM, Helen San Segundo Navazo
>>>>>>>> Hi to all,
>>>>>>>> I've created some wfs on mapserver 6.0.2 and all of them work
>>>>>>>> perfectly
>>>>>>>> with
>>>>>>>> the different requests and wfs versions 1.0.0 and 1.1.0.
>>>>>>>> I've pass from 6.0.2 to 6.2.0 beta2 release to solve the style
>>>>>>>> request
>>>>>>>> problem with raster data sources and now I have problems with the wfs
>>>>>>>> getcapabilities request with 1.1.0 version.
>>>>>>>> With this 1.1.0 version I can't do getcapabilities request, I have no
>>>>>>>> response but there is no problem with describefeaturetype or
>>>>>>>> getfeature
>>>>>>>> requests.
>>>>>>>> With the same 6.2.0 beta2 if I use wfs version= 1.0.0 there is no
>>>>>>>> problem.
>>>>>>>> Anybody knows wich can be the problem?
>>>>>>>> Thanks
>>>>>>>> _______________________________________________
>>>>>>>> mapserver-users mailing list
>>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
