[mapserver-users] MapServer 6.2 beta4 released
thomas bonfort
thomas.bonfort at gmail.com
Thu Sep 27 10:24:29 PDT 2012
The MapServer Team is pleased to announce the release of MapServer 6.2.0 beta4.
This should be our last beta before going RC.
The changelog since beta4 is included in this email, or can be consulted here:
http://www.mapserver.org/en/development/changelog/changelog-6-2-0-beta4.html
The source for this release can be downloaded at:
http://mapserver.org/download.html
or
http://download.osgeo.org/mapserver/mapserver-6.2.0-beta4.tar.gz
The binary distributions listed in the download page should be updated
with binaries for the new 6.2.0-beta4 release in the next couple of days.
Since beta3, we also have updated our test-suite that is now run
automatically at http://ci.mapserver.org . We encourage power users to
submit test cases through the msautotest issue tracker, in the aim of
attaining maximum coverage of MapServer's functionality.
Once again we need your help to ensure a high quality product, so
please help out by testing your applications with this new code base.
Thanks! - The MapServer Team
2012-09-27 18:05:37 +0200 | Thomas Bonfort | avoid segfault when font
file could not be loaded
2012-09-27 14:21:04 +0200 | Thomas Bonfort | fix
ioGetStdoutBufferString() not binary-enabled (#3989)
2012-09-27 11:11:09 +0200 | Stephan Meissl | Harmonizing notation of
Content-Type (not Content-type) header.
2012-09-27 00:05:29 +0200 | Stephan Meissl | Adjusting Content-type
header in WCS 2.0.
2012-09-26 18:47:27 +0200 | Stephan Meissl | Correcting mapscript
methods msIO_stripStdoutBufferContentType() and
msIO_stripStdoutBufferContentHeaders() for new line endings (#4430).
2012-09-24 11:35:21 +0200 | Thomas Bonfort | fix typo leading to
segfault in some multi-label conditions
2012-09-20 09:27:36 +0200 | Yves Jacolin | add configuration for
geometry column in WFS filter for WFS CONNECTIONTYPE layer (#4466)
2012-09-23 18:43:37 +0200 | Thomas Bonfort | undo changes for fastcgi
mapfile caching (#4018)
2012-09-23 18:18:39 +0200 | Thomas Bonfort | fix leaks on mask-skipped
follow labels (#4460)
2012-09-23 11:25:11 +0200 | Thomas Bonfort | more explicit error
message if swig missing
2012-09-21 17:32:02 +0200 | Thomas Bonfort | restore AUTO positioning
of labels around points (#4402)
2012-09-21 11:04:33 +0200 | Thomas Bonfort | fix leaks in LIKE, RE,
IRE filters/expressions (#4461)
2012-09-20 19:50:39 +0200 | Thomas Bonfort | add "make test" target,
can be run with -j
2012-09-20 13:46:29 +0200 | Thomas Bonfort | fix failing postgis
queries on times with no date (#4464)
2012-09-19 21:59:12 +0200 | szekerest | MSSQL: Fix spatial filter test
condition (#4462)
2012-09-16 12:15:25 +0200 | Thomas Bonfort | add support for quotes in
ogc filters, restore previous mapscript setFilter syntax #3983
2012-09-19 13:10:59 +0200 | Thomas Bonfort | fix leaks in drivers
erroneously using LayerClose for LayerCloseConnection
2012-09-18 19:53:38 +0200 | Thomas Bonfort | avoid leak and
unnecessary usage of onlineresource in template output
2012-09-18 10:50:51 +0200 | szekerest | MSSQL2008: Bypass spatial
filtering in certain conditions (#4462)
2012-09-17 19:56:49 +0200 | Thomas Bonfort | numerous memory leak
fixes (wms,wcs,wfs,sos ...)
2012-09-16 15:08:26 +0200 | Thomas Bonfort | use threadsafe time
cleanup/teardown functions (#4458)
2012-09-16 14:12:23 +0200 | Thomas Bonfort | fix memory leaks and
thread-unsafe usage of time parsing (#4458)
2012-09-17 13:48:43 +0200 | szekerest | SDE: Fix for the crash with
CLOB type (#3001)
2012-09-13 11:08:25 +0200 | Thomas Bonfort | add support for svg
symbols in version string
2012-09-12 15:36:32 +0200 | Stephan Meissl | Resolving compiler warning.
2012-07-20 15:51:43 +0200 | Thomas Bonfort | scale dependant
resolution fixes (#4401)
2012-09-11 12:06:23 +0200 | Thomas Bonfort | add SCALE support for
cascaded getlegendgraphic (#4452)
2012-09-10 14:38:05 +0000 | Alan Boudreault | Fix multiple classes in
a inline layer
2012-09-10 14:36:42 +0200 | Thomas Bonfort | avoid integer roundings
in clipping buffer calculation (#179, #4451)
2012-09-09 15:14:28 +0200 | szekerest | Fix MSSQL to parse 3D geometries (#4450)
2012-09-09 15:07:56 +0200 | szekerest | Fix OGR autostyle label
rendering (#4449)
2012-09-09 14:48:59 +0200 | szekerest | Fix drawing legend icons for
annotation layers when no marker symbol is given (#2917)
2012-09-07 14:04:36 +0200 | Stephan Meissl | Fixing attribute
vocabulary not allowed in WMS 1.1.1 (#4447).
2012-09-07 12:00:17 +0200 | Stephan Meissl | Fixing wrong size in
LegendURL of group layers (#4441) and improvements to fix of Style
inheritance in WMS (#4442).
