[mapserver-users] Problems getting FileGDB to work
James Perrins
james.perrins at gmail.com
Thu Apr 4 03:25:15 PDT 2013
We have a server (x64) with mapserver 6.2 on it which is generally running
fine
Until we are trying to access an ESRI FileGDB layer when we keep getting:
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'MMBDLine'.
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
`MMBDLine'. File not found or unsupported format.
</ServiceException>
If we test with shp2img on the same map file - it all works - so obviously
we have the ogr drivers installed on the server ok.
If I use something like sysinternals to check the files accessed - the
mapserver call scans the plugins folder - sees the plugin dll there - but
never seems to load it.
Same call on shp2img appears to access and load the dll properly and all
works
Not seeing any other obvious errors.
Any clues ?
I 've wondered about
- different user accounts - but I don't seem to be getting any access
denied errors.
- 64 bit - I made sure the IIS application pool was 32 bit
- some other pathing issue - do I need a path variable set or somesuch ?
Many Thanks
James
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130404/ef27129e/attachment.html>
