[mapserver-users] Problems getting FileGDB to work
Tamas Szekeres szekerest at gmail.com
Thu Apr 4 05:09:05 PDT 2013
Are you running the cgi mapserv.exe or some other host process loading gdal
and the plugins?
Make sure you use the same architecture (x86/x64) for both the host process
and the plugin. You should also use the matching version of FileGDBAPI.dll
loaded.
You should either place the plugin into a /gdalplugins subdirectory from
where the application is running or use the GDAL_DRIVER_PATH environment
variable to specify the correct location. Also check the file access
permissions so that the dlls can be loaded by the executing user.
Best regards,
Tamas
2013/4/4 James Perrins <james.perrins at gmail.com>
> Hi,
> We have a server (x64) with mapserver 6.2 on it which is generally running
> fine
> Until we are trying to access an ESRI FileGDB layer when we keep getting:
> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'MMBDLine'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
> `MMBDLine'.  File not found or unsupported format.
> </ServiceException>
> If we test with shp2img on the same map file - it all works - so obviously
> we have the ogr drivers installed on the server ok.
> If I use something like sysinternals to check the files accessed - the
> mapserver call scans the plugins folder - sees the plugin dll there - but
> never seems to load it.
> Same call on shp2img appears to access and load the dll properly and all
> works
> Not seeing any other obvious errors.
> Any clues ?
> I 've wondered about
>  - different user accounts - but I don't seem to be getting any access
> denied errors.
>  - 64 bit - I made sure the IIS application pool was 32 bit
>  - some other pathing issue - do I need a path variable set or somesuch ?
> Many Thanks
> James
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130404/32c791b2/attachment.html>
