[mapserver-users] Problems getting FileGDB to work
James Perrins
james.perrins at gmail.com
Thu Apr 4 05:45:55 PDT 2013
Thanks Tamas.
This is a standard mapserver install on IIS - so its a CGI process.
The plugins are in a \gdalplugins folder - which appears to be searched -
but nothing loaded (which made me wonder about x32/x64 issues)
I tried setting GDAL_DRIVER_PATH - but same result
I've set the application pool to run as 32 bit on IIS
CGI mapserver works for other layer types OK - so its basically up and
running
I'm pretty sure mapserver and normall dlls will all be x32 bit anyway
Is there anything particular about an ogr plugin that might be more
sensitive to x32 x64 issues?
Does shp2img bypass these somehow?
Basic install has come from http://www.maptools.org/ms4w/ I believe (I'm
picking this up for someone else at the moment)
Thanks
On 4 April 2013 13:09, Tamas Szekeres <szekerest at gmail.com> wrote:
> Are you running the cgi mapserv.exe or some other host process loading
> gdal and the plugins?
> Make sure you use the same architecture (x86/x64) for both the host
> process and the plugin. You should also use the matching version of
> FileGDBAPI.dll loaded.
> You should either place the plugin into a /gdalplugins subdirectory from
> where the application is running or use the GDAL_DRIVER_PATH environment
> variable to specify the correct location. Also check the file access
> permissions so that the dlls can be loaded by the executing user.
> Best regards,
> Tamas
> 2013/4/4 James Perrins <james.perrins at gmail.com>
>> Hi,
>> We have a server (x64) with mapserver 6.2 on it which is generally
>> running fine
>> Until we are trying to access an ESRI FileGDB layer when we keep getting:
>> <ServiceException>
>> msDrawMap(): Image handling error. Failed to draw layer named
>> 'MMBDLine'.
>> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
>> `MMBDLine'. File not found or unsupported format.
>> </ServiceException>
>> If we test with shp2img on the same map file - it all works - so
>> obviously we have the ogr drivers installed on the server ok.
>> If I use something like sysinternals to check the files accessed - the
>> mapserver call scans the plugins folder - sees the plugin dll there - but
>> never seems to load it.
>> Same call on shp2img appears to access and load the dll properly and all
>> works
>> Not seeing any other obvious errors.
>> Any clues ?
>> I 've wondered about
>> - different user accounts - but I don't seem to be getting any access
>> denied errors.
>> - 64 bit - I made sure the IIS application pool was 32 bit
>> - some other pathing issue - do I need a path variable set or somesuch ?
>> Many Thanks
>> James
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130404/f979a9e0/attachment-0001.html>
