[mapserver-users] WMTS GetFeatureInfo dimensions forward
wellcadmo rwell.well at gmail.com
Wed Apr 10 00:52:02 PDT 2013
I'm trying to make a GetFeatureInfo call to mapcache using WMTS. I have
problems with the dimension parameters. I make my call to mapcache using
some dimension parameters (when I use getMap, all works fine, mapcache send
forwards the params to mapserver), but mapcache send to mapserver that
dimension parameters with the default values.
What I'm doing wrong?
This is part of my apache acces_log file, you can see the forward calls. The
dimension parameter is DIMENSION
WMTS CALL
"GET
/mapcache/wmts/?DIMENSION=00&SERVICE=WMTS&REQUEST=GetFeatureInfo&VERSION=1.0.0&LAYER=EUTM09-BT_paleta1&STYLE=default&TILEMATRIXSET=WGS84&TILEMATRIX=5&TILEROW=9&TILECOL=33&FORMAT=image%2Fpng&INFOFORMAT=application%2Fvnd.ogc.gml&I=11&J=130
HTTP/1.0"
WMS CALL
GET
/cgi-bin/mapserv?VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&STYLES=&FORMAT=image/png&LAYERS=EUTM09-BT&map=/var/www/html/mapserver/mapfile/wmts/meteosat/service_EUTM09-BT_paleta1.map&BBOX=5.625000,33.750000,11.250000,39.375000&WIDTH=256&HEIGHT=256&SRS=EPSG:4326&X=11&Y=130&INFO_FORMAT=application/vnd.ogc.gml&QUERY_LAYERS=EUTM09-BT&DIMENSION=defaultValue
View this message in context: http://osgeo-org.1560.x6.nabble.com/WMTS-GetFeatureInfo-dimensions-forward-tp5045721.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
