[mapserver-users] WMTS GetFeatureInfo dimensions forward
thomas bonfort thomas.bonfort at gmail.com
Wed Apr 10 08:36:18 PDT 2013
This was/is very probably a bug, can you try
https://github.com/mapserver/mapcache/pull/64 and report back in that issue?
regards,
thomas
On 10 April 2013 09:52, wellcadmo <rwell.well at gmail.com> wrote:
> Hi,
> I'm trying to make a GetFeatureInfo call to mapcache using WMTS. I have
> problems with the dimension parameters. I make my call to mapcache using
> some dimension parameters (when I use getMap, all works fine, mapcache send
> forwards the params to mapserver), but mapcache send to mapserver that
> dimension parameters with the default values.
> What I'm doing wrong?
> This is part of my apache acces_log file, you can see the forward calls.
> The
> dimension parameter is DIMENSION
> WMTS CALL
> "GET
> /mapcache/wmts/?DIMENSION=00&SERVICE=WMTS&REQUEST=GetFeatureInfo&VERSION=1.0.0&LAYER=EUTM09-BT_paleta1&STYLE=default&TILEMATRIXSET=WGS84&TILEMATRIX=5&TILEROW=9&TILECOL=33&FORMAT=image%2Fpng&INFOFORMAT=application%2Fvnd.ogc.gml&I=11&J=130
> HTTP/1.0"
> WMS CALL
> GET
> /cgi-bin/mapserv?VERSION=1.1.1&REQUEST=GetFeatureInfo&SERVICE=WMS&STYLES=&FORMAT=image/png&LAYERS=EUTM09-BT&map=/var/www/html/mapserver/mapfile/wmts/meteosat/service_EUTM09-BT_paleta1.map&BBOX=5.625000,33.750000,11.250000,39.375000&WIDTH=256&HEIGHT=256&SRS=EPSG:4326&X=11&Y=130&INFO_FORMAT=application/vnd.ogc.gml&QUERY_LAYERS=EUTM09-BT&DIMENSION=defaultValue
> http://osgeo-org.1560.x6.nabble.com/WMTS-GetFeatureInfo-dimensions-forward-tp5045721.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130410/efca876f/attachment-0001.html>
