[mapserver-users] GetFeatureInfo encoding with HTML template...
Paul james
pauljame at gmail.com
Wed Apr 24 06:33:21 PDT 2013
Tried ISO-8859-1 encondig and it worked fine!
Thanks
On Wed, Apr 24, 2013 at 9:21 AM, Rahkonen Jukka
<jukka.rahkonen at mmmtike.fi>wrote:
> Hi,****
> The same http header works for me as****
> <!-- MapServer Template -->****
> <html>****
> <head>****
> <link rel="stylesheet" href="style.css" type="text/css" />****
> <meta http-equiv="content-type" content="text/html;
> charset=ISO-8859-1"></meta>****
> I do not understand why it does not work for you. What Mapserver do you
> use? Are you sure that you edit the right file? May sound stupid but it has
> happened to me often.****
> -Jukka Rahkonen-****
> Paul james wrote:****
> Hello...****
> I´m using a SQL Server 2008 database and I´m having problem with
> GetFeatureInfo accents using HTML templates... ****
> I need to set encoding to UTF-8...****
> I added that to header.html template:****
> charset=UTF-8"></meta>****
> No success at all... Tried to force html response header on IIS to UTF-8,
> no success as well...****
> How can I solve that problem?****
> Thanks****
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130424/f5027885/attachment-0001.html>
