[mapserver-users] possible bug in oracle spatial support regarding WFS 1.0.0
Holger Porath
porath at web.de
Thu Apr 25 22:11:45 PDT 2013
Andrea!
Thanks for your reply.
The extent is already set on map level but it is not passed over. Here is our complete map file:
MAP
CONFIG "MS_ERRORFILE" "stderr"
NAME sec-data
EXTENT 400000 5000000 500000 6000000
WEB
METADATA
"wfs_title" "test"
"wfs_onlineresource" "http://gdsrve01/cgi-bin/lika-services/private/mapserv_test?"
"wfs_enable_request" "*"
"wfs_srs" "EPSG:25832"
END
END
LAYER
DEBUG 10
NAME flst_gdsrvt01
METADATA
"wfs_title" "flst_gdsrvt01"
"gml_featureid" "fs_id"
"gml_include_items" "all"
"wfs_abstract" "test"
"wfs_extent" "3400000.000000 5400000.000000 3600000.000000 5800000.000000"
END
DUMP TRUE
PROJECTION
"init=epsg:31467"
END
CONNECTIONTYPE oraclespatial
CONNECTION "user/pass at ALKIS_ALBTST.WORLD"
DATA "fs_koordinate from (select fs_koordinate,
fs_gknr,
fs_flnr,
fs_fsz,
fs_fsn,
fs_fsstatus,
gk_gkbez,
fs_id
from os_flst,
gmkg
where gk_gknr=fs_gknr and
fs_fsstatus='a')
USING UNIQUE fs_id NONE VERSION 9i"
TYPE POINT
STATUS ON
END # layer
END # map
Best regards
Holger
Am 25.04.2013 um 20:29 schrieb Andrea Peri:
> I experience a similar (i guess) problem.
> I was resolved when I set the extent a map level.
> 2013/4/25 Holger Porath <porath at web.de>
> Hi all!
> We made some further testing on WFS 1.0.0/ MapServer 6.2.0 and found out that MapServer obviously does not provide an extent when calling msOracleSpatialLayerWhichShapes. The MapServer debug log shows following entry:
> msOracleSpatialLayerWhichShapes. Bind values: srid:-1 minx:0.000000 miny:0.000000 maxx:0.000000 maxy:0.000000
> msQueryByRect(): Search returned no results. No matching record(s) found.
> msProjectRect(): Warning: degenerate rect {0.000000,0.000000,0.000000,0.000000}
> The same getFeature (filter) request with WFS version set from 1.0.0 to 1.1.0 works correctly and the log then reads:
> msOracleSpatialLayerWhichShapes. Bind values: srid:-1 minx:400000.000000 miny:5000000.000000 maxx:500000.000000 maxy:6000000.000000
> It seems that this is a bug that came in with MapServer 6.x. If we submit a WFS 1.0.0 request to map server 5.6.3 everything is fine and the debug log states:
> msOracleSpatialLayerWhichShapes. Bind values: srid:-1 minx:399996.701914 miny:5399998.334331 maxx:600003.563487 maxy:5800001.763759
> Is there anybody who can fix this and provide a patch so that we can recompile MapServer?
> Thanks in advance.
> Holger
> mapserver-users at lists.osgeo.org
> Andrea Peri
> qwerty àèìòù
