[mapserver-users] Mapserver 6.2.1 upgrade breaks Mapcache
thomas bonfort
thomas.bonfort at gmail.com
Fri Apr 26 05:20:21 PDT 2013
Native MapServer support in mapcache is considered experimental and
shouldn't really be enabled in production unless you know what you're
doing. That said...
- are you using mapcache from the ubuntu-gis repo?
- if not, and you do not need native mapserver support, then recompile
mapcache without mapserver support
- otherwise, you can probably just symlink libmapserver-6.2.0.so to
libmapserver-6.2.1.so <http://libmapserver-6.2.0.so/>
thomas
On 26 April 2013 14:10, Worth Lutz <wal3 at mindspring.com> wrote:
> I upgraded my Ubuntu (12.04) system today and MapServer upgraded to 6.2.1.
> sudo apt-get upgrade
> upgraded packages: cgi-mapserver mapserver-bin php5-mapscript
> I tried to restart apache2 to update my MapCache config and it failed with:
> Cannot load /usr/lib/apache2/modules/mod_mapcache.so into server:
> libmapserver-6.2.0.so: cannot open shared object file: No such file or
> directory
> Action 'configtest ' failed.
> Do I need to reinstall MapCache? What is the procedure to fix this? How can
> I avoid this problem in the future?
> Thanks,
> Worth
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130426/30c2864a/attachment.html>
