[mapserver-users] wms works with version 1.1.1 but not with 1.3.0
Daniel Morissette dmorissette at mapgears.com
Mon Apr 29 06:27:08 PDT 2013
And for a longer explanation about this axis order difference between
WMS 1.1.1 and 1.3.0 as well as some examples to help understand it, see:
http://dmorissette.blogspot.ca/2012/12/dont-upgrade-to-wms-130-unless-you.html
On 13-04-29 9:02 AM, thomas bonfort wrote:
> Are you inverting the axis order in your BBOX= param for the wms 1.3.0
> requests (needed if you're requesting in epsg:4326) ?
> thomas
> On 29 April 2013 14:43, <Andre.Steinhaeuser at lung.mv-regierung.de
> <mailto:Andre.Steinhaeuser at lung.mv-regierung.de>> wrote:
>     Hello,
>     I am trying to set up a wms server with one layer. Mapserver version
>     is 5.6.1.
>     A getmap-request asking for Version 1.1.1 or 1.1.0 returns an image
>     containing the information(lines) of the layer, including scale bar
>     and legend. When i use a getmap-request for version 1.3.0 it returns
>     a white image and the scale bar an legend but no error. I cannot
>     find any error in my mapfile, but i am sure, there is one. Can
>     anyone help me with finding my fault.
>     Thanks a lot,
>     regards,
>     Andre
>     +++Mapfile starts+++
>     MAP
>        NAME Lawa
>        Size 600 300
>        EXTENT 5 47 15 55
>        #IMAGECOLOR 123 123 255
>        PROJECTION
>         "init=epsg:4326"
>        END
>        SYMBOLSET './symbols/symbols.sym'
>        SCALEBAR
>          STATUS EMBED
>          UNITS kilometers
>          INTERVALS 3
>          TRANSPARENT TRUE
>          OUTLINECOLOR 0 0 0
>          POSITION UR
>        END
>        LEGEND
>          STATUS EMBED
>          POSITION LR
>          TRANSPARENT TRUE
>        END
>        OUTPUTFORMAT
>          NAME "jpg"
>          DRIVER AGG/jpeg
>          MIMETYPE "image/jpg"
>          IMAGEMODE RGB
>          EXTENSION "jpg"
>        END
>        UNITS DD
>        WEB
>          IMAGEPATH '/tmp/'
>          # Set IMAGEURL to the url that points to IMAGEPATH
>          # as defined in your web server configuration
>          IMAGEURL '/tmp/'
>          # WMS server settings
>            METADATA
>              "wms_title" "LAWA-Typen-WMS-Server MV"
>              "wms_onlineresource"
>     "http://www.fis-wasser-mv.de/cgi-bin/mapserv?map=/home/fgsk/mapserver/LAWA/lawa-wms2.map&"
>              "wms_srs" "EPSG:4326"
>            END
>        END
>        LAYER
>          NAME 'Lawa-Typen'
>          EXTENT 5 47 15 55
>          TYPE LINE
>          STATUS DEFAULT
>          INCLUDE "dbconnection.include"
>          DATA "the_geom from (Select gid, the_geom, ty_cd_rw, rwb_name
>     FROM raw.rwbody_wk_de) as FOO USING UNIQUE gid USING srid=4326"
>          METADATA
>            "wms_title" "LAWA-Typen"
>            "wms_format" "image/jpg"
>          END
>          PROJECTION
>            "init=epsg:4326"
>          END
>          #MINSCALEDENOM 1000
>          #MAXSCALEDENOM 1000000000
>          CLASS
>            STYLE
>              COLOR 0 0 0
>            END
>          END
>        END
>     END
>     +++Mapfile ends+++
>     _______________________________________________
>     mapserver-users mailing list
>     mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/mapserver-users
Daniel Morissette
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
