[mapserver-users] wms works with version 1.1.1 but not with 1.3.0
thomas bonfort thomas.bonfort at gmail.com
Mon Apr 29 06:02:03 PDT 2013
Are you inverting the axis order in your BBOX= param for the wms 1.3.0
requests (needed if you're requesting in epsg:4326) ?
thomas
On 29 April 2013 14:43, <Andre.Steinhaeuser at lung.mv-regierung.de> wrote:
> Hello,
> I am trying to set up a wms server with one layer. Mapserver version is
> 5.6.1.
> A getmap-request asking for Version 1.1.1 or 1.1.0 returns an image
> containing the information(lines) of the layer, including scale bar and
> legend. When i use a getmap-request for version 1.3.0 it returns a white
> image and the scale bar an legend but no error. I cannot find any error in
> my mapfile, but i am sure, there is one. Can anyone help me with finding my
> fault.
> Thanks a lot,
> regards,
> Andre
> +++Mapfile starts+++
> MAP
>   NAME Lawa
>   Size 600 300
>   EXTENT 5 47 15 55
>   #IMAGECOLOR 123 123 255
>   PROJECTION
>    "init=epsg:4326"
>   END
>   SYMBOLSET './symbols/symbols.sym'
>   SCALEBAR
>     STATUS EMBED
>     UNITS kilometers
>     INTERVALS 3
>     TRANSPARENT TRUE
>     OUTLINECOLOR 0 0 0
>     POSITION UR
>   END
>   LEGEND
>     STATUS EMBED
>     POSITION LR
>     TRANSPARENT TRUE
>   END
>   OUTPUTFORMAT
>     NAME "jpg"
>     DRIVER AGG/jpeg
>     MIMETYPE "image/jpg"
>     IMAGEMODE RGB
>     EXTENSION "jpg"
>   END
>   UNITS DD
>   WEB
>     IMAGEPATH '/tmp/'
>     # Set IMAGEURL to the url that points to IMAGEPATH
>     # as defined in your web server configuration
>     IMAGEURL '/tmp/'
>     # WMS server settings
>       METADATA
>         "wms_title" "LAWA-Typen-WMS-Server MV"
>         "wms_onlineresource" "
> http://www.fis-wasser-mv.de/cgi-bin/mapserv?map=/home/fgsk/mapserver/LAWA/lawa-wms2.map&
>         "wms_srs" "EPSG:4326"
>       END
>   END
>   LAYER
>     NAME 'Lawa-Typen'
>     EXTENT 5 47 15 55
>     TYPE LINE
>     STATUS DEFAULT
>     INCLUDE "dbconnection.include"
>     DATA "the_geom from (Select gid, the_geom, ty_cd_rw, rwb_name FROM
> raw.rwbody_wk_de) as FOO USING UNIQUE gid USING srid=4326"
>     METADATA
>       "wms_title" "LAWA-Typen"
>       "wms_format" "image/jpg"
>     END
>     PROJECTION
>       "init=epsg:4326"
>     END
>     #MINSCALEDENOM 1000
>     #MAXSCALEDENOM 1000000000
>     CLASS
>       STYLE
>         COLOR 0 0 0
>       END
>     END
>   END
> END
> +++Mapfile ends+++
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130429/141d2b45/attachment.html>
