[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
Andrea Peri
aperi2007 at gmail.com
Tue Aug 13 09:31:54 PDT 2013
ok, thx.
I change to multiple scale.
However I do a rapid check removing a label component, but the problem is
still here.
Now I rewrite a more exact mapfile using two classes.
Andrea.
2013/8/13 thomas bonfort <thomas.bonfort at gmail.com>
> yes, that's incompatible. use multiple scale-dependant classes for now
> On 13 August 2013 18:26, Andrea Peri <aperi2007 at gmail.com> wrote:
> > The two label are at different max/min scaledenominator.
> > The goal is to have little label size at low scales and bigger font size
> at
> > bigger scales.
> > However only one lable is active at one scale level.
> > Is this incompatible with "follow" ?
> >> why the double label? they seem to be the same, but in any case
> >> multiple labels are not supported for FOLLOW.
> >> On 13 August 2013 18:08, Andrea Peri <aperi2007 at gmail.com> wrote:
> >> > I'm using spatialite 4.1.1,
> >> > so use ogr to access the db.
> >> > LAYER
> >> > NAME "rt_topogr.50k.etichette.topon_idro_50k"
> >> > STATUS OFF
> >> > EXTENT 1554750.74 4678325.52 1771722.76 4924791.90
> >> > TYPE LINE
> >> > CONNECTIONTYPE OGR
> >> > CONNECTION "/path-to-spatialite/zz_topografica.sqlite"
> >> > DATA "select PK_UID_2, TOPO_OK, GEOMETRY from topon_idro_50k"
> >> > PROJECTION
> >> > "+init=epsg:3003 +towgs84=0,0,0,0,0,0,0"
> >> > END
> >> > METADATA
> >> > "wms_title" "topon_idro_50k"
> >> > "wms_extent" "1554750.74 4678325.52 1771722.76 4924791.90"
> >> > END
> >> > LABELCACHE ON
> >> > MAXSCALEDENOM 60100
> >> > MINSCALEDENOM 1
> >> > CLASS
> >> > NAME ''
> >> > MAXSCALEDENOM 60100
> >> > MINSCALEDENOM 1
> >> > LABEL
> >> > TEXT '[TOPO_OK]'
> >> > COLOR 0 85 255
> >> > OUTLINECOLOR 212 255 255
> >> > OUTLINEWIDTH 1
> >> > MAXSCALEDENOM 60100
> >> > MINSCALEDENOM 40100
> >> > FONT "LiberationSans-Regular"
> >> > TYPE truetype
> >> > SIZE 7
> >> > ANGLE FOLLOW
> >> > OFFSET 15 99
> >> > POSITION auto
> >> > PRIORITY 10
> >> > MAXOVERLAPANGLE 180.0
> >> > BUFFER 1
> >> > FORCE OFF
> >> > PARTIALS FALSE
> >> > MINDISTANCE 200
> >> > END
> >> > LABEL
> >> > TEXT '[TOPO_OK]'
> >> > COLOR 0 85 255
> >> > OUTLINEWIDTH 1
> >> > MAXSCALEDENOM 40100
> >> > MINSCALEDENOM 1
> >> > TYPE truetype
> >> > SIZE 9
> >> > ANGLE FOLLOW
> >> > OFFSET 15 99
> >> > POSITION auto
> >> > PRIORITY 10
> >> > BUFFER 1
> >> > FORCE OFF
> >> > PARTIALS FALSE
> >> > MINDISTANCE 200
> >> > END
> >> > END
> >> > END
> >> >> there's something strange in your error message... the
> >> >> singleSidedBuffer stuff is in GEOS, and should have nothing to do in
> >> >> msOGRFileNextShape. post your whole mapfile layer.
> >> >> On 13 August 2013 17:42, Andrea Peri <aperi2007 at gmail.com> wrote:
> >> >> > Hi,
> >> >> > I tested trasforming the multilinestring dataset in a linestring
> >> >> > dataset
> >> >> > but
> >> >> > the error is still here.
> >> >> > msDrawMap(): Image handling error. Failed to draw layer named
> >> >> > 'rt_topogr.50k.etichette.topon_idro_50k'.
> >> >> > msOGRFileNextShape(): OGR error. IllegalArgumentException:
> >> >> > BufferBuilder::bufferLineSingleSided only accept linestrings
> >> >> > So it is not really due to a multilinestring vs linestring
> question.
> >> >> > The quest carry on.
> >> >> > 2013/8/13 Andrea Peri <aperi2007 at gmail.com>
> >> >> >> Hi,
> >> >> >> Try.ing to set a label on a MULTILINESTRING dataset.
> >> >> >> I set a label with Follow capability.
> >> >> >> ANGLE FOLLOW
> >> >> >> But I'm having this error:
> >> >> >> Is the Follow compatible with a MultiLinestring dataset or need
> only
> >> >> >> simple linestrings ?
> >> >> >> Thx,
> >> >> >> Andrea Peri
> >> >> >> qwerty àèìòù
> >> >> > Andrea Peri
> >> >> > qwerty àèìòù
> >> >> > _______________________________________________
> >> >> > mapserver-users mailing list
> >> >> > mapserver-users at lists.osgeo.org
> >> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> >> > Andrea Peri
> >> > qwerty àèìòù
> > Andrea Peri
> > qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130813/be34d3ac/attachment.html>
