[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
Andrea Peri
aperi2007 at gmail.com
Tue Aug 13 14:31:32 PDT 2013
Perhaps I found the explanation.
The "angle follow" with OGR is using the
BufferBuilder::bufferLineSingleSided
That function seem don't work with a MultiLinestring . It necessary need a
simple linestring.
The question is that sometime the simple linestirng when is clipped from
the visible bbox of the map to render, is transformed in a MultiLinestring.
As showed in attached image.
So a linestring geometry clipped by the visible bbox will become a
multilinestring geometry and the bufferLineSingleSided will give error to
put a "follow angle".
Andrea.
2013/8/13 Andrea Peri <aperi2007 at gmail.com>
> ok, thx.
> I change to multiple scale.
> However I do a rapid check removing a label component, but the problem is
> still here.
> Now I rewrite a more exact mapfile using two classes.
> Andrea.
> 2013/8/13 thomas bonfort <thomas.bonfort at gmail.com>
>> yes, that's incompatible. use multiple scale-dependant classes for now
>> On 13 August 2013 18:26, Andrea Peri <aperi2007 at gmail.com> wrote:
>> > The two label are at different max/min scaledenominator.
>> > The goal is to have little label size at low scales and bigger font
>> size at
>> > bigger scales.
>> > However only one lable is active at one scale level.
>> > Is this incompatible with "follow" ?
>> >> why the double label? they seem to be the same, but in any case
>> >> multiple labels are not supported for FOLLOW.
>> >> On 13 August 2013 18:08, Andrea Peri <aperi2007 at gmail.com> wrote:
>> >> > I'm using spatialite 4.1.1,
>> >> > so use ogr to access the db.
>> >> > LAYER
>> >> > NAME "rt_topogr.50k.etichette.topon_idro_50k"
>> >> > STATUS OFF
>> >> > EXTENT 1554750.74 4678325.52 1771722.76 4924791.90
>> >> > TYPE LINE
>> >> > CONNECTIONTYPE OGR
>> >> > CONNECTION "/path-to-spatialite/zz_topografica.sqlite"
>> >> > DATA "select PK_UID_2, TOPO_OK, GEOMETRY from topon_idro_50k"
>> >> > PROJECTION
>> >> > "+init=epsg:3003 +towgs84=0,0,0,0,0,0,0"
>> >> > END
>> >> > METADATA
>> >> > "wms_title" "topon_idro_50k"
>> >> > "wms_extent" "1554750.74 4678325.52 1771722.76 4924791.90"
>> >> > END
>> >> > LABELCACHE ON
>> >> > MAXSCALEDENOM 60100
>> >> > MINSCALEDENOM 1
>> >> > CLASS
>> >> > NAME ''
>> >> > MAXSCALEDENOM 60100
>> >> > MINSCALEDENOM 1
>> >> > LABEL
>> >> > TEXT '[TOPO_OK]'
>> >> > COLOR 0 85 255
>> >> > OUTLINECOLOR 212 255 255
>> >> > OUTLINEWIDTH 1
>> >> > MAXSCALEDENOM 60100
>> >> > MINSCALEDENOM 40100
>> >> > FONT "LiberationSans-Regular"
>> >> > TYPE truetype
>> >> > SIZE 7
>> >> > ANGLE FOLLOW
>> >> > OFFSET 15 99
>> >> > POSITION auto
>> >> > PRIORITY 10
>> >> > MAXOVERLAPANGLE 180.0
>> >> > BUFFER 1
>> >> > FORCE OFF
>> >> > PARTIALS FALSE
>> >> > MINDISTANCE 200
>> >> > END
>> >> > LABEL
>> >> > TEXT '[TOPO_OK]'
>> >> > COLOR 0 85 255
>> >> > OUTLINEWIDTH 1
>> >> > MAXSCALEDENOM 40100
>> >> > MINSCALEDENOM 1
>> >> > TYPE truetype
>> >> > SIZE 9
>> >> > ANGLE FOLLOW
>> >> > OFFSET 15 99
>> >> > POSITION auto
>> >> > PRIORITY 10
>> >> > BUFFER 1
>> >> > FORCE OFF
>> >> > PARTIALS FALSE
>> >> > MINDISTANCE 200
>> >> > END
>> >> > END
>> >> > END
>> >> >> there's something strange in your error message... the
>> >> >> singleSidedBuffer stuff is in GEOS, and should have nothing to do in
>> >> >> msOGRFileNextShape. post your whole mapfile layer.
>> >> >> On 13 August 2013 17:42, Andrea Peri <aperi2007 at gmail.com> wrote:
>> >> >> > Hi,
>> >> >> > I tested trasforming the multilinestring dataset in a linestring
>> >> >> > dataset
>> >> >> > but
>> >> >> > the error is still here.
>> >> >> > msDrawMap(): Image handling error. Failed to draw layer named
>> >> >> > 'rt_topogr.50k.etichette.topon_idro_50k'.
>> >> >> > msOGRFileNextShape(): OGR error. IllegalArgumentException:
>> >> >> > BufferBuilder::bufferLineSingleSided only accept linestrings
>> >> >> > So it is not really due to a multilinestring vs linestring
>> question.
>> >> >> > The quest carry on.
>> >> >> >> Hi,
>> >> >> >> Try.ing to set a label on a MULTILINESTRING dataset.
>> >> >> >> I set a label with Follow capability.
>> >> >> >> ANGLE FOLLOW
>> >> >> >> But I'm having this error:
>> >> >> >> Is the Follow compatible with a MultiLinestring dataset or need
>> only
>> >> >> >> simple linestrings ?
>> >> >> >> Thx,
>> >> >> >> Andrea Peri
>> >> >> >> qwerty àèìòù
>> >> >> > Andrea Peri
>> >> >> > qwerty àèìòù
>> >> >> > _______________________________________________
>> >> >> > mapserver-users mailing list
>> >> >> > mapserver-users at lists.osgeo.org
>> >> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >> > Andrea Peri
>> >> > qwerty àèìòù
>> > Andrea Peri
>> > qwerty àèìòù
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130813/326bed80/attachment.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130813/326bed80/attachment.gif>
