[mapserver-users] mapcache: How can I configure an attributionlayer with mapcache?
Martin Kofahl martin.kofahl at gmail.com
Thu Feb 14 03:20:27 PST 2013
Hi Ariane,
you may configure to add a watermark (from png file, etc) in the tileset
section. See http://mapserver.org/en/mapcache/config.html.
<!-- watermark
      optional tag to add a watermark to the tiles *before* storing
them to cache      the supplied image MUST be exactly the same size as
the size of the tiles      configured in the <grid>      the supplied
image is read when the configuration is loaded.      if you make
changes to the image, they will NOT be reflected on tiles already
stored in the cache, nor on newly stored tiles until the server is
restarted-->
<watermark>/path/to/static/watermark.png</watermark>
Martin
2013/2/14 Ariane Brörmann <ariane.broermann at googlemail.com>
> Is there a possibility to add an attributionlayer (copyright) with
> mapcache?
> If yes, how can I configure this?
> Ariane
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130214/af12a47e/attachment.html>
