[mapserver-users] mapcache: How can I configure an attributionlayer with mapcache?
Ariane Brörmann ariane.broermann at googlemail.com
Fri Feb 15 00:37:34 PST 2013
Thank you for this hint and the quick answer.
I have already tried the watermark but the label appears on every tile.
I would like to have the label at a bottom corner only once, no matter of
how many tiles my image consists.
2013/2/14 Martin Kofahl <martin.kofahl at gmail.com>
> Hi Ariane,
> you may configure to add a watermark (from png file, etc) in the tileset
> section. See http://mapserver.org/en/mapcache/config.html.
> <!-- watermark
>       optional tag to add a watermark to the tiles *before* storing them to cache      the supplied image MUST be exactly the same size as the size of the tiles      configured in the <grid>      the supplied image is read when the configuration is loaded.      if you make changes to the image, they will NOT be reflected on tiles already      stored in the cache, nor on newly stored tiles until the server is restarted-->
> <watermark>/path/to/static/watermark.png</watermark>
> Martin
> 2013/2/14 Ariane Brörmann <ariane.broermann at googlemail.com>
>> Is there a possibility to add an attributionlayer (copyright) with
>> mapcache?
>> If yes, how can I configure this?
>> Ariane
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130215/9d704772/attachment.html>
