[mapserver-users] tips to draw a symbol‏
Havard Tveite havard.tveite at umb.no
Wed Feb 27 00:21:53 PST 2013
Creating vector symbols:
Unless you have a formulae, you will have to measure.
In 6.2, precise placement of symbols is easy using SYMBOL
ANCHORPOINT.  It is therefore possible to split a complex
symbol into more manageable parts (for instance some parts
using lines and some parts using polygons), and then combine
them using STYLEs.
Håvard
On 2/26/2013 10:21 AM, Gery wrote:
> Hello Håvard,
> Thanks for your answer, I tested yesterday in my 5.6 version and it also works well, the problem is that after changing the values during many hours I couldn't set properly the right value to get that "opened v", so I think just doing random changes here and there won't help me to draw well this figure. I was thinking about some tips to draw this image, I think first I should take a piece of paper and draw this image and then take the measurements from it, is this the right, easy way to do it? those values in v-poly were calculated in this way?
> Gery
> Date: Tue, 26 Feb 2013 00:07:25 -0800
> From: [hidden email] </user/SendEmail.jtp?type=node&node=5036887&i=0>
> To: [hidden email] </user/SendEmail.jtp?type=node&node=5036887&i=1>
> Subject: Re: tips to draw a symbol‏
> Dear Gary,
> The v-poly symbol should be OK (I just tested it with
> 6.2 and 5.6.6).  If you want an open V, you should
> use only outlinecolor:
>         STYLE
>           SYMBOL "v-poly"
>           SIZE 30
>           OUTLINECOLOR 0 255 0
>         END # STYLE
> Håvard
> On 2/26/2013 12:36 AM, Gery wrote:
>  > Hello folks,
>  > I've been trying to draw the attached image but with no luck, I've used
>  > "v-poly" from http://mapserver.org/mapfile/symbology/construction.html but
>  > couldn't get the opened "v" effect, could anyone please provide some tips to
>  > draw such image? I'll appreciate it, thanks in advance.
>  > Regards,
>  > Gery
>  > View this message in context: http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813.html
>  > Sent from the Mapserver - User mailing list archive at Nabble.com.
>  > _______________________________________________
>  > mapserver-users mailing list
>  > [hidden email] <http:///user/SendEmail.jtp?type=node&node=5036860&i=0>
>  > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5036860&i=1>
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813p5036860.html
> To unsubscribe from tips to draw a symbol‏, click here.
> NAML <http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble:email.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble:email.naml-instant_emails%21nabble:email.naml-send_instant_email%21nabble:email.naml>
> View this message in context: RE: tips to draw a symbol‏ <http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813p5036887.html>
> Sent from the Mapserver - User mailing list archive <http://osgeo-org.1560.n6.nabble.com/Mapserver-User-f4226646.html> at Nabble.com.
> mapserver-users at lists.osgeo.org
Håvard Tveite
