[mapserver-users] tips to draw a symbol‏
Gery gamejihou at hotmail.com
Wed Feb 27 01:44:28 PST 2013
Thanks again Håvard, and the SYMBOL
ANCHORPOINT is not present in version 5.6, right? splitting and then combining as you suggest is the solution for me. How about measuring? is there any tip? imagine I have a simple notebook with graph paper, I draw (or print) there the image I want to reproduce in mapserver and then measure it in centimeters? milimeters?
__________________________________________________________________________________________
Piensa en el medio ambiente - mantenlo en la pantalla. NO lo imprimas si NO es necesario.
Think green - keep it on the screen. Do NOT print if it is NOT necessary.
Denken Sie an die Umwelt - bewahren Sie es auf dem Bildschirm. Drucken Sie es NICHT, wenn es NICHT notwendig ist.
Date: Wed, 27 Feb 2013 00:22:19 -0800
To: gamejihou at hotmail.com
Subject: Re: tips to draw a symbol‏
	Creating vector symbols:
Unless you have a formulae, you will have to measure.
In 6.2, precise placement of symbols is easy using SYMBOL
ANCHORPOINT.  It is therefore possible to split a complex
symbol into more manageable parts (for instance some parts
using lines and some parts using polygons), and then combine
them using STYLEs.
Håvard
On 2/26/2013 10:21 AM, Gery wrote:
> Hello Håvard,
> Thanks for your answer, I tested yesterday in my 5.6 version and it also works well, the problem is that after changing the values during many hours I couldn't set properly the right value to get that "opened v", so I think just doing random changes here and there won't help me to draw well this figure. I was thinking about some tips to draw this image, I think first I should take a piece of paper and draw this image and then take the measurements from it, is this the right, easy way to do it? those values in v-poly were calculated in this way?
> Gery
> Date: Tue, 26 Feb 2013 00:07:25 -0800
> From: [hidden email] </user/SendEmail.jtp?type=node&node=5036887&i=0>
> To: [hidden email] </user/SendEmail.jtp?type=node&node=5036887&i=1>
> Dear Gary,
> The v-poly symbol should be OK (I just tested it with
> 6.2 and 5.6.6).  If you want an open V, you should
> use only outlinecolor:
>         STYLE
>           SYMBOL "v-poly"
>           SIZE 30
>           OUTLINECOLOR 0 255 0
>         END # STYLE
> Håvard
> On 2/26/2013 12:36 AM, Gery wrote:
>  > Hello folks,
>  > I've been trying to draw the attached image but with no luck, I've used
>  > "v-poly" from http://mapserver.org/mapfile/symbology/construction.html but
>  > couldn't get the opened "v" effect, could anyone please provide some tips to
>  > draw such image? I'll appreciate it, thanks in advance.
>  > Regards,
>  > Gery
>  > View this message in context: http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813.html
>  > Sent from the Mapserver - User mailing list archive at Nabble.com.
>  > mapserver-users mailing list
>  > [hidden email] <http:///user/SendEmail.jtp?type=node&node=5036860&i=0>
>  > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Håvard Tveite
> Department of Mathematical Sciences and Technology, UMB
> Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
> Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5036860&i=1>
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813p5036860.html
> To unsubscribe from tips to draw a symbol‏, click here.
> NAML <http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble:email.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble:email.naml-instant_emails%21nabble:email.naml-send_instant_email%21nabble:email.naml>
> View this message in context: RE: tips to draw a symbol‏ <http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813p5036887.html>
> Sent from the Mapserver - User mailing list archive <http://osgeo-org.1560.n6.nabble.com/Mapserver-User-f4226646.html> at Nabble.com.
> [hidden email]
Håvard Tveite
[hidden email]
		http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813p5037177.html
		NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/tips-to-draw-a-symbol-tp5036813p5037202.html
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130227/f3d472ab/attachment-0001.html>
