[mapserver-users] RE [Polluriel potentiel] Re: RE null value renders in pie chart SOLVED
Steve.Toutant at inspq.qc.ca
Thu Jan 3 10:42:33 PST 2013
I'm using 6.1, these 2 solutions work!
preprocess your data to replace NULLs by 0, or use a DATA statement on a
postgis layer to do that for you ( e.g. DATA "the_geom from (select gid,
the_geom, COALESCE(cri,0) AS cri from mytable) as foo using uninque gid" )
Thank you for your fantastic help,
Steve
thomas bonfort <thomas.bonfort at gmail.com>
2013-01-03 13:18
A
cc
MapserverList OSGEO <mapserver-users at lists.osgeo.org>,
mapserver-users-bounces at lists.osgeo.org
Objet
[Polluriel potentiel] Re: [mapserver-users] RE null value renders in pie
chart
Note that EXPRESSION support was added to pie layers in 6.2 only. I'd say
your best bet is to preprocess your data to replace NULLs by 0, or use a
DATA statement on a postgis layer to do that for you ( e.g. DATA "the_geom
from (select gid, the_geom, COALESCE(cri,0) AS cri from mytable) as foo
thomas
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130103/c00f042b/attachment.html>
