[mapserver-users] [TinyOWS] TinyOWS 1.1.0 and the old good axis order trouble
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Thu Jan 31 00:45:29 PST 2013
Hi Olivier,
Sorry for the late response.  I analyzed finally what axis order alternatives the srs_wkt field in the spatial_ref_sys table contains and the situation is a bit more complicated than you have believed.  This is the result of a SELECT DISTINCT query
1)      AXIS[""Easting"",EAST],AXIS[""Northing"",NORTH]]"
2)      AXIS[""X"",EAST],AXIS[""Y"",NORTH]]"
3)      AXIS[""Northing"",NORTH],AXIS[""Easting"",EAST]]"
4)      AXIS[""X"",NORTH],AXIS[""Y"",EAST]]"
5)      AXIS[""Y"",EAST],AXIS[""X"",NORTH]]"
6)      AXIS[""X"",SOUTH],AXIS[""Y"",WEST]]"
7)      AXIS[""Y"",NORTH],AXIS[""X"",EAST]]"
8)      AXIS[""E(X)"",EAST],AXIS[""N(Y)"",NORTH]]"
9)      AXIS[""x"",NORTH],AXIS[""y"",EAST]]"
10)   AXIS[""Easting"",UNKNOWN],AXIS[""Northing"",UNKNOWN]]"
11)   AXIS[""none"",NORTH],AXIS[""none"",EAST]]"
12)   AXIS[""X"",UNKNOWN],AXIS[""Y"",UNKNOWN]]"
13)   AXIS[""Northing"",UNKNOWN],AXIS[""Easting"",UNKNOWN]]"
My conclusions:
Must not be flipped: 1, 2, 8
Must be flipped: 3, 4, 9
Probably should not be flipped: 10, 12
Probably should be flipped: 11, 13
No idea: 5, 6, 7
The most important system for me is EPSG:3067 and it has the WKT as in alternative 1:  AXIS[""Easting"",EAST],AXIS[""Northing"",NORTH]]"
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Olivier Courtin
Lähetetty: 18. joulukuuta 2012 9:10
Vastaanottaja: Mapserver-Users (mapserver-users at lists.osgeo.org)
Aihe: Re: [mapserver-users] [TinyOWS] TinyOWS 1.1.0 and the old good axis order trouble
On Mon, Dec 17, 2012 at 11:16 AM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi<mailto:Jukka.Rahkonen at mmmtike.fi>> wrote:
Hi Jukka,
Nice to see you again here :)
I have been running TinyOWS r558 for quite a long time because it is dealing almost right with the axis order of the projections I am commonly using. Now I had a fast try with the current TinyOWS 1.1.0 version but unfortunately I realized that it is doing wrong thing by flipping the axis with urn:ogc:def:crs:EPSG::3067.
On this topic we will not make any progress, without a regression test.
(OGC CITE don't cover this issue)
Could you provide from a single point stored in the database,
requests and answers awaited ?
I could also try to write it by myself too,
but will definitly need you to read it back,
for all eastern stuff...
What is the logic that TinyOWS is using when it decides whether the axis should be flipped or not  for WFS 1.1.0?
Mainly 2 factors, as i recall:
 - if it's SRS or CRS (meaning EPSG:xxxx or urn:ogc:def:crs:EPSG::xxxx)
 - if SRTEXT contain both AXIS["X",NORTH]] and AXIS["Easting",EAST]]
Olivier
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130131/85db89f7/attachment-0001.html>
