[mapserver-users] Help install MapCache
thomas bonfort thomas.bonfort at gmail.com
Thu Nov 28 12:01:56 PST 2013
You can comment out the mapguide service from your mapcache.xml
configuration file. Are you using an older version of mapcache? (the
mapguide service was added in 1.2 iirc)
regards,
thomas
On 28 November 2013 20:55, moisessalgado <moises.pgser at gmail.com> wrote:
> Hi everyone,
> I am newbie in MapServer, but I was succeed on set up a WMS service with a
> single tile. Now I am trying to set up MapCache to work with WMS service
> using tiles but I am stuck on the MapCache installation. I am following the
> steps in http://mapserver.org/mapcache/install.html but when I edit
> '/etc/apache2/sites-available/default' and add the following lines...:
> LoadModule mapcache_module    modules/mod_mapcache.so
> <IfModule mapcache_module>
>    <Directory /var/www/mapcache>
>       Order Allow,Deny
>       Allow from all
>    </Directory>
>    MapCacheAlias /mapcache "/var/www/mapcache/mapcache.xml"
> </IfModule>
> ... and then, when I try to restart apache I get the error:
> * Starting web server apache2
> [Thu Nov 28 17:48:09 2013] [warn] module mapcache_module is already loaded,
> skipping
> Syntax error on line 38 of /etc/apache2/sites-enabled/000-default:
> unknown <service> type mapguide
> Action 'start' failed.
> The Apache error log may have more information.
> The line 38 of '/etc/apache2/sites-enabled/000-default' is:
> The complete content of '/etc/apache2/sites-enabled/000-default' is:
> <VirtualHost *:80>
>         ServerAdmin webmaster at localhost
>         DocumentRoot /var/www
>         <Directory />
>                 Options FollowSymLinks
>                 AllowOverride None
>         </Directory>
>         <Directory /var/www/>
>                 Options Indexes FollowSymLinks MultiViews
>                 AllowOverride None
>                 Order allow,deny
>                 allow from all
>         </Directory>
>         ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
>         <Directory "/usr/lib/cgi-bin">
>                 AllowOverride None
>                 Options +ExecCGI -MultiViews +SymLinksIfOwnerMatch
>                 Order allow,deny
>                 Allow from all
>         </Directory>
>         ErrorLog ${APACHE_LOG_DIR}/error.log
>         # Possible values include: debug, info, notice, warn, error, crit,
>         # alert, emerg.
>         LogLevel warn
>         CustomLog ${APACHE_LOG_DIR}/access.log combined
>                Order Allow,Deny
>                Allow from all
>             </Directory>
>         </IfModule>
> </VirtualHost>
> Could someone help me understand and resolve this issue?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-install-MapCache-tp5091744.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
