[mapserver-users] MapServer for Windows
Ben Crane
curtly.boon at gmail.com
Wed Aug 6 01:56:56 PDT 2014
Hey guys,
Under the downloads page on http://www.gisinternals.com/sdk/ do I need to
do incremental installs (ie: install one thing, then another, etc)? Or is
it all self-contained? The reason I ask is that I go to
*release-1600-gdal-1-11-mapserver-6-4
*(which is stable and win32) and under that I have a few options - do I
need Mapserver core first then the others or can I go with release
1600-gdal zip?
I'm guessing that I do a standard install (latest) and then whenever
updates come along (as mentioned by others) I replace the various libraries
with the updates so that made me think there may be a split in what I
should be downloading first...
Cheers,
Ben
On Tue, Aug 5, 2014 at 4:42 PM, Ben Crane <curtly.boon at gmail.com> wrote:
> Hey guys,
> Many thanks for this - I'll give it a go - all the suggestions have been
> different to what I've seen before so that's great - makes me feel like I'm
> on the right path now.
> Much appreciated
> Ben
> On Tue, Aug 5, 2014 at 12:31 PM, Rahkonen Jukka (Tike) <
> jukka.rahkonen at mmmtike.fi> wrote:
>> Hi,
>> The ”relevant binaries” means copying into the cgi-bin directory of MS4W
>> all the .dll files from \release-1600-gdal-mapserver.zip\bin\ as well as
>> mapserv.exe from \release-1600-gdal-mapserver.zip\bin\ms\apps\. I believe
>> that 32-bit binaries must be used.
>> I made a short test with my old MS4W installation and Apache did start
>> and all the old mapfiles I tried were working after these substitutions.
>> However, from previous experience I know that mixed binaries can make
>> troubles. I also believe that Mapserver is losing users because we lack an
>> easy way to install current version on Windows.
>> -Jukka Rahkonen-
>> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
>> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Tamas Szekeres
>> *Lähetetty:* 5. elokuuta 2014 13:47
>> *Vastaanottaja:* Ben Crane
>> *Kopio:* MapserverList OSGEO
>> *Aihe:* Re: [mapserver-users] MapServer for Windows
>> If you still using ms4w+Apache, try replacing the relevant binaries from
>> release-1600 builds from http://www.gisinternals.com/sdk/ which should
>> be a compatible build well enough, though PHP is not being compiled at the
>> moment. You can also download an IIS based msi installer with CGI
>> registration capabilities (not fastCGI) from
>> http://www.gisinternals.com/sdk/.
>> Best regards,
>> Tamas
>> 2014-08-05 11:36 GMT+02:00 Ben Crane <curtly.boon at gmail.com>:
>> Hey all,
>> Mapserver for Windows :)
>> I've seen a bit about this online but sometimes more information can be
>> more confusing. I've used MS4W before and loved it but I have noticed the
>> versions are getting far removed from the latest build and that concerns
>> me. I would like to install MapServer (including the admin webpage (which
>> made life a lot easier)) but the latest version - apparently there has been
>> a fix to the PolygonSymbolizer stroke-opacity not working within Mapserver
>> that I'd like to try out. I will be primarily using it to build a WMS
>> service.
>> Can anyone suggest from personal experience which his the best route to
>> go to get the latest Mapserver (including upgrades/new builds, etc) for
>> Windows?
>> Cheers,
>> Ben
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140806/46c6a43c/attachment.html>
