[mapserver-users] MapServer for Windows
Tamas Szekeres szekerest at gmail.com
Wed Aug 6 02:06:30 PDT 2014
Ben,
The packages on http://www.gisinternals.com/sdk/ are self contained the
mapserver-core.msi would be enough for the basic mapserver functionality.
You can also install the gdal plugin packages (oracle, filegdb, ecw) into
the same directory to add further driver support to gdal.
Best regards,
Tamas
2014-08-06 10:56 GMT+02:00 Ben Crane <curtly.boon at gmail.com>:
> Hey guys,
> Under the downloads page on http://www.gisinternals.com/sdk/ do I need to
> do incremental installs (ie: install one thing, then another, etc)? Or is
> it all self-contained? The reason I ask is that I go to *release-1600-gdal-1-11-mapserver-6-4
> *(which is stable and win32) and under that I have a few options - do I
> need Mapserver core first then the others or can I go with release
> 1600-gdal zip?
> I'm guessing that I do a standard install (latest) and then whenever
> updates come along (as mentioned by others) I replace the various libraries
> with the updates so that made me think there may be a split in what I
> should be downloading first...
> Cheers,
> Ben
> On Tue, Aug 5, 2014 at 4:42 PM, Ben Crane <curtly.boon at gmail.com> wrote:
>> Hey guys,
>> Many thanks for this - I'll give it a go - all the suggestions have been
>> different to what I've seen before so that's great - makes me feel like I'm
>> on the right path now.
>> Much appreciated
>> Ben
>> On Tue, Aug 5, 2014 at 12:31 PM, Rahkonen Jukka (Tike) <
>> jukka.rahkonen at mmmtike.fi> wrote:
>>>  Hi,
>>> The ”relevant binaries” means copying into the cgi-bin directory of MS4W
>>> all the .dll files from \release-1600-gdal-mapserver.zip\bin\ as well as
>>> mapserv.exe from \release-1600-gdal-mapserver.zip\bin\ms\apps\.  I believe
>>> that 32-bit binaries must be used.
>>> I made a short test with my old MS4W installation and Apache did start
>>> and all the old mapfiles I tried were working after these substitutions.
>>> However, from previous experience I know that mixed binaries can make
>>> troubles. I also believe that Mapserver is losing users because we lack an
>>> easy way to install current version on Windows.
>>> -Jukka Rahkonen-
>>> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
>>> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Tamas Szekeres
>>> *Lähetetty:* 5. elokuuta 2014 13:47
>>> *Vastaanottaja:* Ben Crane
>>> *Kopio:* MapserverList OSGEO
>>> *Aihe:* Re: [mapserver-users] MapServer for Windows
>>> If you still using ms4w+Apache, try replacing the relevant binaries from
>>> release-1600 builds from http://www.gisinternals.com/sdk/ which should
>>> be a compatible build well enough, though PHP is not being compiled at the
>>> moment. You can also download an IIS based msi installer with CGI
>>> registration capabilities (not fastCGI) from
>>> http://www.gisinternals.com/sdk/.
>>> Best regards,
>>> Tamas
>>> 2014-08-05 11:36 GMT+02:00 Ben Crane <curtly.boon at gmail.com>:
>>> Hey all,
>>> Mapserver for Windows :)
>>> I've seen a bit about this online but sometimes more information can be
>>> more confusing. I've used MS4W before and loved it but I have noticed the
>>> versions are getting far removed from the latest build and that concerns
>>> me. I would like to install MapServer (including the admin webpage (which
>>> made life a lot easier)) but the latest version - apparently there has been
>>> a fix to the PolygonSymbolizer stroke-opacity not working within Mapserver
>>> that I'd like to try out. I will be primarily using it to build a WMS
>>> service.
>>> Can anyone suggest from personal experience which his the best route to
>>> go to get the latest Mapserver (including upgrades/new builds, etc) for
>>> Windows?
>>> Cheers,
>>> Ben
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140806/c248faf4/attachment-0001.html>
